Old 01-09-2024, 09:44 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Default speedmaster roller rockers
i got a deal on some edelbrock heads that came with some 1.52 roller rockers by speedmaster. theyre similar to ls rockers thats had the trunion upgraded to a bushing. anyone run these? they look nicely built but that dont mean nothing
Old 01-10-2024, 05:20 AM
Schurkey Schurkey is offline
Anything sold by "Speedmaster" is supremely questionable in terms of quality. Anything they sell that could cause catastrophic failure should not be used.
Consider giving them a military-style "Flotation test".
Old 01-10-2024, 07:01 AM
steve25 steve25 is offline
If your able to find out what spring pressure there rated for I would back that down by 20% to use them safely.
Old 01-10-2024, 08:36 AM
P@blo's Avatar
P@blo P@blo is offline
Only a couple of aluminum brands are worth running. I use the clunky gold ones that have a good reputation but they cost a few more bucks.
The bitterness of high prices wear off much quicker than poor quality does.
Old 01-10-2024, 08:55 AM
i think the guy i got the heads from was using them on a hft cam so probably not alot of spring pressure. i do like the bushed fulcrum vs needle bearings so i wish i could find the name brand version theyre cloning.
i snagged a set of crower aluminum 1.7s off here a few weeks back i plan to run but i need to see what spring pressures theyre good for also
