Old 03-03-2000, 03:44 PM
bob macey bob macey is offline
My 72 Conv has rusted out flanges on the automatic transmission crossmember. I thought I could put any cross member from that year in the car ,now I've been told that I need one from a conv or a455 model with a boxed frame , is this true? Is this part going to be hard to find, maybe I should weld up my rusted one. Thanks for any info you all might have one this question, Bob
Old 03-03-2000, 07:38 PM
stevep's Avatar
stevep stevep is offline
Figure out what the original length was and add the nessessary amount to it.If you don't have a welder yourself,it shouldn't cost that much to have a shop do it.
If you buy a used one,it would probably already have been fixed.So fix yours and save a few bucks!
Old 03-03-2000, 09:17 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
There are only 2 crossmembers....All 1968-72 A body "convertible" crossmembers are the same shorter because of "boxed" frame. All 1968-72 A body "hardtop" crossmembers are the same. That's Chevelle, Cutlass, 442, GS, etc. + 69-72 GP and I think 69-72 Monte Carlo. Good crossmembers are not hard to find (especially dry climate areas.
