69 GTO wiring harness
can you use a wiring harness that had full gauges on a car that has idiot lights my 69 has the standard idiot lights but the wiring harness is cut up and i have a good wiring harness but it came from a car with full gauges
Yes, you can use it but you need to switch a couple of wires.
This should help you. http://forums.maxperformanceinc.com/...ghlight=gauges
Get some rally gauges,wire it in.E-bay or even a want ad here will get it done.Unless your doing a factory correct resto..
72 Luxury Lemans nicely optioned |
Thanks for the info I will fallow its advice .I would like to keep the car original and I run after market gauges under the dash anyways
