Old 02-19-2012, 08:17 AM
Jeff Hamlin's Avatar
Default 1967 HO fuel filter CLOSE UP
Can anyone with a HO '67 give me a "Close Up" pic of the fuel filter/bracket at the front on the front of the intake.
Everything I've found online doesn't show a clear view.
Thanks.
Old 02-19-2012, 11:26 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 67 GTO Filter/Bracket
Jeff, not as close-up as I would like but this is all I can offer for now. It did not matter if Standard or HO as the 67's had the fuel filter secured with a right angle metal bracket that was held in place off the water outlet neck stud and nut. Many of these brackets were removed as they are extremely difficult to access for service. The filter would be secure without it because of the rigid fuel lines. The bracket is OEM correct and is nice to see on any correct 67!
Name:	67 HO - Calif. A.I.R..jpg
ID:	275370   Click image for larger version
Name:	67 Original Std. GTO Conv. Survivor.jpg
ID:	275371   Click image for larger version
Name:	67 GTO Original Insulated Sending Unit.jpg
Old 02-19-2012, 12:02 PM
60sstuff's Avatar
Default Another Pic
Be aware that the early 67's (non-air, and air condition models) all had the "3 line" set-up with that small vapor return. Later 67's went to the single fuel line. Below is another pic showing the OEM installation from a forum member.
Name:	67 GTO Fuel Filter Location.jpg
Old 02-19-2012, 12:04 PM
WOW, That's what I need, I take it the bracket is bolted to the water neck?
It that bracket avail in repo?
Old 02-19-2012, 12:54 PM
richardk's Avatar
richardk richardk is offline
Here are a couple pics of mine, repro bracket and replacement filter that doesn't quite fit the bracket.
Both the bracket and the correct repop filter available.
I have modified the fuel line from filter to carb on mine to fit the longer carb inlet I'm using.
ID:	275376Click image for larger version
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 09-12-2020, 04:44 PM
gto19's Avatar
gto19 gto19 is offline
Old thread ... I know
does anyone have one of these original fuel filter brackets laying around I could buy . My original bracket is missing the round part so it must’ve broke some time ago
Thanks guys
gto19@att.net
