Old 08-16-2020, 02:50 PM
bb400ho bb400ho is offline
Default wanted charcoal canister
i need a charcoal canister and bracket for a 78 trans am. shipping would be to 16423. let me know if you can help
thanks Bryan
Old 08-16-2020, 10:01 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Would one from my 74 work?
Old 08-17-2020, 09:56 AM
burd's Avatar
burd burd is offline
I have a nOS one in the box. Not cheap. Exact replacement, not the superseded One w/ extra port on. I wouldn’t use a used one, when the screen rusts out, all the pellets get sucked into the carb.
Don’t worry About the shipping, lol.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 08-17-2020, 10:25 AM
i appreciate the response. NOS is probably not the option for my car. was a 403 now a 400. trying to make it correct it enough to get past emissions test in Pittsburgh.
thanks Bryan
Old 08-25-2020, 08:33 AM
Default Charcoal canister
Bump
Old 08-29-2020, 07:58 PM
burd's Avatar
Is the 403 a diff #?
F ire B irds
Old 08-30-2020, 07:29 AM
77 Canamman's Avatar
17056978 is correct for either the Pontiac or Oldsmobile engine.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 08-30-2020, 09:40 AM
burd's Avatar
New in the box bro. Or Put a used one on, when all the pellets go in your carb, it’s a fun day.
F ire B irds
Old 08-31-2020, 08:31 AM
burd's Avatar
Nothing like nOS very hard to find part. I’m sure there’s tubs of rusted out used ones.
F ire B irds
Old 08-31-2020, 10:54 AM
Default canister
the pellets in my carb is why the canister is gone. i just wish i didnt remove the bracket also. ok ill ask how much is a nos canister?
thanks Bryan
Old 08-31-2020, 01:26 PM
burd's Avatar
There is a cheaper way to go, the canister fir the GN Fits, and is a superseded part, they were like $45. It even comes with a plug for the extra port. Look for one, I bought the last one year one had on the shelf when mine went. I was told it has charcoal wadding in, not pellets too.
F ire B irds
Old 08-31-2020, 09:46 PM
4dblnkldude's Avatar
I just pulled one out yesterday. Has the bracket on the bottom i believe
Old 09-01-2020, 04:28 PM
unruhjonny's Avatar
couldn't you drain everything out the bottom of one of these, and close it back up?
I mean it's really only there to pass the visual part of the inspection, odds are none of the kids doing the inspections know how or what to do about them... isn't it like a hollowed out cat - if it passes the sniffer, and it passes the visual inspection, you should be good to go right?
1970 Formula 400
Old 09-01-2020, 04:48 PM
yes i could. if i couldn't find a functional one that was my plan. probably will end up with BB's in the hoses anyway. i wish thats what i would have done to begin with when it went bad. instead i put a '72 manifold on with no egr and a spring choke and got rid of all the old stuff. i figured it already had an emission sticker on it and if you go less than 5k miles its exempt. Then my daughter and her friend to a 6k mile trip in it. i used to have an inspection station but thats no longer the case.
Old 09-01-2020, 04:50 PM
is it a 78 (4 port)? how much shipped to 16423? also let me know if you have any of the other valves. i dont need the egr valve or the vacuum port on the manifold but pretty much need the rest of it
thanks bryan
Old 09-01-2020, 09:32 PM
thanks bryan
Yes it is the 4 port, I hear nothing rattling around in there. It has two little clip brackets and it bolts to the bottom. PM me your address, I'll send it to you. No money just pay it forward.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 09-02-2020, 10:55 AM
burd's Avatar
If you go with a used one, I’ve seen guys put a lager riding lawnmower fuel filter in the purge line, you can’t tell if the screen is rusted out unless you cut it open.
The later one has wadding in I was told.
F ire B irds
Thread Tools
Display Modes
