Old 09-07-2020, 08:59 AM
540goat 540goat is offline
Default Dual gate shifter position and cable hole.
I am putting a dual gate shifter in my 67 and need some measurements of where the shifter is placed and the hole for the cable is drilled.
Old 09-08-2020, 10:46 PM
squidtone's Avatar
squidtone squidtone is offline
540goat,
I took these pictures of my Hurst dual gate in my 67 something like 15 years ago (gasp). I only have two measurements....note where the tape measure (at 9 inches or so) is over the center of the floor seam at the top of the tunnel. Then the end of the tape measure is at the shifter bracket with the cable coming out. I didn't put tape measure at hole location, but maybe you can calculate by using a ruler as a reference to the tape measure in the picture. Note too the gaffer tape the factory used under the hole plug, the wooden (plywood-ish) washers under the shifter mounting bolts (factory from what I've read).
Good luck.
Dave
ID:	549100   Click image for larger version
ID:	549101   Click image for larger version
Dave
http://www.squidsfabshop.com/?
(updated January, 2013, Pypes exhaust installation)
Old 09-09-2020, 05:43 AM
Originally Posted by squidtone View Post
540goat,
Good luck.
Dave
Thank you very much for taking the time to post this. This is exactly what I needed.
