Need help,thinking of going from a Quadrajet to a
Holley,Edelbrock or Demon carb for the Ventura. It's pretty much a street car that going to see alot of dragstrip racing. I'm having problems with the quadrajet flooding with my Robb Mc fuel pump even though i have a regulator set on 5 psi.
What do yall suggest,750 or 800 cfm,vacuum or mechanical secondaries? I would like something simple and easy to tune. 1972 Ventura, car weighs 3315 by itself 455 .30 over ported 6x heads 91cc Torker 1 intake crower 60919 470 lift 231/240 duration long branch manifolds turbo 350 2800 stall 3.23 gear |
my 2 cents- A Holley 750 double pumper.
http://www.machdevelopment.com/album...775/527566.htm |
Holley 750 DP with a 1 inch wilson 4 hole tapered spacer.
Less said,,,,,,,, Less mended. |
Agree, a Holley 750 DP would gave excellent response on the street and would be a good match for the Long Branch manifolds.
Tom Vaught
Thanks for the advice, i borrowed a Holley 750 vacuum sec carb from a friend and so far i like it. Only problem is i'm not getting full throttle but i'll deal with that tomorrow.
Is there any reason nobody has recommended a Demon? I use one before on my '75 Formula years ago and it worked fairly decent. |
Karl |
I would like to have Cliff rebuild it but he has a 10 month wait. I guess i'll order a kit from him and have a friend of mine rebuild it and swap them around at the track to see what works better. If you look at my video below you will how bad it stumbles at the track.
I have a 750cfm Speed Demon carb purchased in 2004 and have had the secondary float get stuck on me twice; flooding the motor. It's a shame because it's pretty easy to work on and tune.
Added commentsThe Rochester Quadrajet is a great carburetor. GM used them for many years and put them as standard equipment on literally millions of vehicles. The design was improved over the years and they came with many different calibrations depending on engine size and vehicle type. They were used from around 1967 up until they were replaced by fuel injection. This should tell you that they are a good design. The Q-Jet can be calibrated to work on a variety of engine sizes on both granny cars with a 326 to HP vehicles with a 455. Even the Pontiac overcam six banger came with a Q-jet. On the downside they are old, worn out, complex and your average hobbiest does not want to mess with them or does not know how to modify/repair them to make them work properly. It's so easy to just toss it aside and put a Holley on it. To make a 40 plus year old Q-jet work properly it does need to be repaired, modified and calibrated to work with your combo. Once this task has been done correctly you will love your street machine with a Q-Jet. On a street or street strip car the Q-Jet will not bog, leak or otherwize fall short of your expectations. The Q-Jet (in proper repair and calibration) will run just as hard as a Holley at the dragstrip up to a certain performance level. I believe there is one exception as I believe the Q-Jet may not be as well suited for a HP manual shift car as a mechanical secondary Holley might be. But on the street the Q-Jet will have better fuel economy, produce fewer hydrocarbons and run just as hard as any Holley. Getting the 40 plus year old fuel mixer to perform like a swiss watch is a challange unless you happen to be Cliff Ruggles. If you like to tinker and you have the time you can get Cliff's book and the parts from him and do the repair/modifications and calibrations your self. It's not just a matter of installing a kit. You could stick a Holley on there for a year or so until you can get Cliff to does his magic, or you can just stick that Holley double pumper 750 on there and that should work great.
I didn't want anyone to think that Cliff is the only one who can build a great Q-Jet. There are others that can build a nice Q-Jet but there are so many out there building crap that it's a scary world. I believe carbking also knows his way around a Q-Jet and Holley and others for that matter.
Tim Corcoran Last edited by Tim Corcoran; 12-19-2012 at 08:21 PM. Reason: Added Comments |
To add to Tim's comment, you could post the number of the QJet you are using, and maybe someone here could help.
One issue many bring upon themselves is trying to use either too large an orifice in the fuel valve seat or too much fuel pressure. Another issue is trying to use a "windowed" seat with the earlier float design. Your issue might be very easy to correct. And obtaining a copy of Cliff's book might be a good start. I have read a lot of books on carbs in the last 50 years, and Cliff's ranks in the top 3 regardless of brand, or cost. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
Russ, I just finished going through Cliff's book and rebuilt a spare carb using his recipe. It turned out great. Just put it on my car and started it today. Not that difficult but there is a learning curve involved. Cliff was very accessible to answer my questions.
I'm going to do it again for my '68's carb. Personally, I really like Q-Jets.
Greg Reid Palmetto, Georgia |
Greg,i have always like quadrajets until reasonally,this one is drving me crazy. On the original 350 it ran great,no bogging issues or starting problems at all. |
Russ, that just tells me that it was set up right for the 350...but not for this engine. As for flooding, sounds like something that could be figured out. Maybe dial the pump down to 4 pounds?
Use another gauge to measure the pressure after the regulator. It sounds like there is still more than 5psi getting to the carb.
Why all this love for double pumpers on the street? A vacuum secondary carb is going to have better manners, better fuel economy, and likely will produce quicker times off the line. Size becomes much more important with mechanical secondaries. A vacuum carb will simply only open up the secondaries as far as needed, so you can easily get away with going large.
With the ethanonal that is in todays gas can have an effect on the tip of the needle valve, not letting it seal right and contribute to the flooding problem also. But do get Cliff's book and read it (and have your carb man read it also) before you just buy a kit and rebuild the carb. The larger engine, headwork, cam and exhaust all have an effect on carb performance.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
mighty demon
Nothing wrong with a holley( i have one on the '62), but, If thats the only problem you are having, you should call Cliff, order his complete kit, get his book and redo your carb. If its idling and driving around just fine, and it only does it, after you are in the throttle, it could be that the secondary flap is sticking open, or you are running too big needle valve... i'd run the .135 Needle and seat... You will feel better about your car, if , you use what you have.... I believe , if done correctly, it'll out perform the holley(with your 3.23 gears and stall)... and its more impressive when you open the hood If i can do it, anybody can do it. I just did an 800cfm Buick for my Wagon...did the whole Cliff treatlment to it...and i love it... Cant wait til SPring!!!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft 1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!! |
The carb # is 17057274 off of a 1977 Firebird.
Same exact number I use on my 455. It has over 1200 drag strip runs on it with zero issues, and 4 trips to the final round at Norwalk in the Stock Class. I run 7.5 psi fuel pressure on it, from a Comp 140gph electric pump and 8AN lines. Here's a clip from Norwalk, timing retarded 4 degrees and shifting at 5000rpm's to stay roll bar legal: http://www.youtube.com/watch?v=6zVdoLR-VzM I also have an electric choke on it for instant cold weather starts and fast idle while it warms up. When you get time, contact the shop and I'll set you up with a custom kit and tuning parts, so it's basically just "plug and play" for your builder.....Cliff
Damn Cliff...my car is faster than that! LOL. Nice run. How's that 400 build coming?
I would tinker with the Q-Jet before going the Holley route. My second choice for carbs would be a quick fuel or pro systems mainly because I have heard the customer support is awesome for either of these companies. Plan to spend $500 - $700
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
