#41
Old 05-21-2017, 08:12 AM
BobC BobC is offline
No early ones. The seller is going to supply the '70-'73 valance braces for both sides in order to convert the fenders for my car. The NOS fenders are the early '80's service replacement parts that use the clip nut for attaching the hood hinges.
  #42
Old 05-21-2017, 12:33 PM
After closer examination I'm not sure where the origin of the new fenders actually is... At least I didn't pay a NOS price for them. Ignorance and excitement make a bad combination when making purchases!
  #43
Old 05-21-2017, 01:53 PM
marxjunk marxjunk is offline
we all have been there..ive done it so many times...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
  #44
Old 05-22-2017, 11:33 AM
I need some help from the forum in determining the origin of some unused '70-'81 TA fenders I recently purchased. Does anyone have some NOS GM fenders from the early '80's that used the clip nut for attaching the hood hinges? Also, when did the first repop fenders become available? The seller said that the fenders in question came with a project car back in the '80's. The unused fenders are not near the quality of the factory installed fenders and the gauge of some of the inner structure bracing is thinner. There is residue from where an ID sticker used to be on the inside of the fender.
  #45
Old 05-22-2017, 11:44 AM
77 Canamman's Avatar
Lightbulb
Here is an NOS Fender on E-Bay:
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #46
Old 05-22-2017, 02:02 PM
Norwood's Avatar
Norwood Norwood is offline
Pictures
  #47
Old 05-22-2017, 06:26 PM
FASTASSBIRD FASTASSBIRD is offline
ID:	455163Click image for larger version
I got this one. But I think it's a 77 and up
  #48
Old 05-22-2017, 06:29 PM
Better picture of the part number
  #49
Old 05-22-2017, 09:52 PM
Not looking good... Compared to the known NOS parts there are multiple discrepancies. The metal is bulged around the wheelhouse bolt holes. There are three additional holes under the extractors. The ID labels have been deliberately removed plus they had square corners versus rounded like GM. The labels were located inside below the extractors. The GM labels I've seen are located inside above the wheel openings. Guess I'll post them on CL with an accurate description and price accordingly. Maybe someone can use them on a drag car, they're lighter!
ID:	455179   Click image for larger version
ID:	455180   Click image for larger version
  #50
Old 05-23-2017, 09:07 AM
bird72's Avatar
bird72 bird72 is offline
years ago I bought a TA fender like that from GM dealer. I took it as a generic "one size fits all" replacement with the different flare holes. not good ole early thick sheetmetal.
72 Bird
  #51
Old 09-14-2019, 09:04 PM
Picked these up for the ‘72 Firebird. I’ve seen them installed in early ‘70’s Birds. Looking for input from someone who has done this before. What seat tracks were used and what mods were needed.
  #52
Old 09-16-2019, 04:00 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Those seats look like they are from a 1981 NASCAR Edition Trans Am. Are the track adapters still on them? Should be able to just bolt up a factory set of seat tracks.
That model of Recaro seat is called the Ideal-N. Back in the day they sold multiple track adapters for different car models. The adapters are basically just made of folded and stamped 1/8" plate steel and painted black.
  #53
Old 09-16-2019, 04:26 PM
72projectbird's Avatar
I have them in my 71. I think I just bolted my 71 tracks directly to the adapters and they worked perfectly.
I robbed the interior out of my 81 while it's under the knife.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #54
Old 09-17-2019, 10:01 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
Great find!
YE automatic trans block...WOW
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #55
Old 09-17-2019, 09:35 PM
The seats were recently removed from an ‘81 NASCAR TA. They have the adapter brackets. The ‘81 seat tracks are longer than my ‘72’s. The holes in the ‘72 tracks have to be slotted about another 1/2” in order to bolt them to the Recaro adapters. The Recaro adapter brackets need to have material removed to allow the ‘72 seat track release lever to clear.
  #56
Old 08-07-2020, 01:52 PM
Default Part ID needed
The bodyshop disassembled parts of the car and didn’t bag or tag some parts. The tech who did the work is no longer employed there. Could someone please ID where these shims came from? I’m guessing deck lid or doors. Thanks, Bob
  #57
Old 08-07-2020, 09:47 PM
cnc's Avatar
cnc cnc is offline
I believe those are trunk lid shims????? ..is your trunk lid adjusted properly
Just quick question u keep the tail panel black. I personally like the look and thinkin the same on my car or going white....
Love to see pics again
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
  #58
Old 08-08-2020, 01:20 PM
Car will be painted Buccaneer red including the tail panel. Still in the early stages of mocking up and gapping body panels. I waited 3 years for the first shop to get an opening and it didn’t work out. I’m working on getting the project back on track at another bodyshop.
  #59
Old 08-08-2020, 01:54 PM
cnc's Avatar
cnc cnc is offline
Nice ....that sucks on the wait that's a long time and then have to go elsewhere good luck with it all and look forward to pics
Mines going in for paint End of Nov
  #60
Old 12-21-2020, 09:26 PM
Even on a rotisserie scraping heavy undercoating is a crappy job. I used a heat gun and scraping tools to get off most of it. Then used a spray bottle with odorless mineral spirits to keep it soaked while wiping it down with red Scotch-Brite and rags. Nice weather tomorrow so I’m going to blast the rusty areas.
Subframe has been blasted. Sprayed with epoxy and then black Imron.
ID:	556631   Click image for larger version
ID:	556632   Click image for larger version
