Old 03-09-2020, 10:40 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Default Anti reversion plates?
I’m thinking of trying an anti reversion plate on my Tiger head/ intake 535. Has anybody tried there and what are your thoughts. I see several companies make these.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 03-10-2020, 12:48 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
It’s trial and error. Some motors like other spacers more than others.
I tried a anti reversion plate on my Pontiac motor,it helped and picked up the car a bit. I tried and found my Stinnet spacer worked much better.
That was without my #1 stop on the intake. Just the carb/spacer/intake.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 03-10-2020, 06:19 AM
steve25 steve25 is offline
There's no cut in stone answer on this , but in general that kind of Carb spacer helps to dampen reversion pulses when your intakes Plenum is short on volume to do the dampening.
In a motor like yours with a proper sized/ tuned Intake runner lenght the normal reversion pulse that takes place in a NA motor will stop and reverse at a distance of about 1 1\2" beyond the end of the runner, not up closer to the bottom of the Carb where it can push air and fuel back up out of the Carbs Venturi.
Old 03-10-2020, 09:12 AM
slowbird's Avatar
slowbird slowbird is offline
Bill C really seems to like them on the Tiger intake. Might want to contact him.
Old 03-10-2020, 09:19 AM
I’ve got a 2” KVH tapered spacer on there now but it’s simply too tall. I’ve got to find something 1/2” to 1” that’s why I’m looking. I “heard” in the past that it works well in the Tiger intake?
Old 03-10-2020, 09:41 AM
Gary H's Avatar
Gary H Gary H is offline
Jimmy, I put Wilson Manifold shear plates under my dual Holley carbs and it picked up .10 in the 60 ft time. Car was much more responsive off the line. I had to send them the manifold top for them to cut down so they would fit but in my opinion it was worth it.
Old 03-10-2020, 02:56 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Have seen the Reher Morrison 2 piece one work well within a narrow RPM range (target range) on a 400.
It was probably correcting a runner length / cam / exhaust tuning issue, but with a single 4 it's a little hard to change alot there.
Trial a d error is the only way, and it may only work in a narrow range, but it could be a cheap fix for a hole in a Tq curve as well until the real issue is found./solved
Working on going faster (and now staying dry at the same time !!)
Old 03-10-2020, 03:20 PM
It might work well with my throttle stop as well.
Old 03-10-2020, 04:13 PM
Mike Davis's Avatar
I am running the Reher Morrison plates on my 446 with the Wenzler Tunnel Ram. Car picks up a tenth with them.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 03-10-2020, 05:39 PM
Gary H's Avatar
I would think it would.
Old 03-11-2020, 09:06 AM
I ordered the Reher and Morrison plate and we,ll see how it works. I’ll report back if it helps.
Old 03-11-2020, 11:39 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I made two of these some years ago for my father... Extra thin mounting pad.. Built for a big wenzler gutsram 517 engine running two 1050 carbs I think..... Not reporting any hp gains but the engine ran a lot smoother and had much better throttle response afterwards.
*** THE BIG BRACE is here ***
Old 03-11-2020, 03:55 PM
Dragncar Dragncar is offline
How do these compare with a "Super Sucker" type spacer ? The Reher Morrison plate are not expensive at all compared to a SS.
Old 03-11-2020, 06:28 PM
Mark G Mark G is offline
Holy skills Batman.. really nice job I use a super sucker right now maybe I will try a reversion plate ..
Old 03-11-2020, 08:36 PM
That looks bad a$$ !!
Old 07-30-2020, 11:31 AM
Allan Runions2's Avatar
Allan Runions2 Allan Runions2 is offline
Well... Did it help?
93 GP chrome-moly round tube car. 525 IA2. STD E-Heads by S&D, Steel rods, ALKY injected. S/pro car. Best ET 8.25@163mph
65 GTO back-half car. 468 e-headed S/pro car. 9.30-40s
(Sold to my father)
81 Lemans wagon. 10.70 pro/no box car. SOLD
Old 07-31-2020, 11:53 PM
cfmcnc cfmcnc is offline
The most popular Reversion plates with ditch surrounding a shear lip works best when the port SEES the ditch and it is not shrouded from the view up the port to the ditch.What happens is in milliseconds of the exhaust energy pulse pushing back up the roof of the intake tract slames into the ditch and turns around coming down the shear lip side pulling on the incoming charge helping accelerate the incoming charge.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
Old 08-01-2020, 09:42 AM
The NHRA season shut down until recently. The Southern National will be my next race and then I’ll know
Old 08-01-2020, 07:21 PM
Half-Inch Stud's Avatar
Im sure reversion starts on the exhausr side. and Solved with the exhaust Collector length.
The word SOLVED being used. Surely the Cam profile (overlap) begins the need for a sufficient exhaust Collect length.
Seems to me, the only way to push fuel/air back up the carb venturis is with Exhaust-originated reversion.
