Old 07-24-2020, 09:40 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default Cam for Blown 535...
My new cam for a 535/wide port combo. 12.5:1, methanol, 8-71 blower all going in a 3300 lb 69 GTO...goal is 1200ish HP with 20 lbs of boost...anyone see any issues with this cam and that goal?
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
Old 07-24-2020, 05:19 PM
Lee's Avatar
Lee Lee is offline
Looks like WAY more intake duration than you should need, and a lot of overlap - to me. I suspect you'll be blowing a lot of unburned alcohol right out the exhaust.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
The Following User Says Thank You to Lee For This Useful Post:
Old 07-25-2020, 03:55 PM
69Goat1's Avatar
The recommendation came from comp cams on this...I bought it new so I hope they knew what they were talking about...
