Old 07-27-2020, 02:54 PM
79Dreamer 79Dreamer is offline
Default Hey Newbie with a 79
Hey I just scored on a 79!! It's actually my 3rd bird, the first 2 I had in High school.
I'm a grease junky so I know my way around, been working on cars since I was 14 so it's been over 30 years.
I got a concern that maybe someone can clarify for me. Got a 200-4R I've had sitting in my garage for over 15 years. It was running fine off a mid 80's Monte Carlo LS that had 90K miles. I plan on rebuilding it better w/TCI Pro kit and swapping it for of my 79.
I know that my rear gears are not preferable for it but my question is that it should still be ok right? The cars fron the mid 80's had gears similar to my 2.41 and worked ok.
Must I change it or .....see how it goes? Which of these 3 ratios should I get if I have to 3.42, 3.55 or 3.73 ??
I plan on building a SBC 383 if my 403 gives out, It's running fine now.
It can fishtail off the line!!!
Thanks guys!!
Old 07-27-2020, 08:29 PM
Poncho Dave Poncho Dave is offline
Going to be changing the motor if you change the Trans as I would assume the tranny will only bolt to a Chevy block.
Old 07-28-2020, 12:40 AM
The 200-4r has both bell housing holes for BOP and Chevy
Old 07-28-2020, 03:32 AM
Aus78Formula Aus78Formula is offline
And you'd be going with different ratios for a torquey 403 and a chev that likes to wind out instead. Regardless, you'll need a new carrier to suit the centre.
Old 07-28-2020, 07:43 AM
77 Canamman's Avatar
As much as I don't care for the 403, I would retain it, with better heads and intake. The bottom end is the weak link in that chain.
Pontiac 400/455 would put a smile on your face.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 07-28-2020, 07:50 AM
put that 383 in with the 2.41 rear and let us know how impressive it is off the line. It also depends if you want people to notice you roaring around town.
Old 07-28-2020, 11:05 AM
Grand73Am Grand73Am is offline
The Monte Carlo with the 200-4r in it had 3.42 rear gears, so that would be the ratio to use. With the overdrive, those mid-80's cars didn't use 2.41's or 2.56's. So, the transmission change wouldn't be worth it unless you swap the rear gears. Since you have 2.41's, you'll have to change the carrier also to use 3 series gears.
Steve F.
The Following User Says Thank You to Grand73Am For This Useful Post:
