Edelbrock intake port length?
Anyone know the intake port length?
Brian,
Numbers are from Larry Meaux. Int=5.163 Exh=5.623 Int=131.1 Exh=142.8 Edelbrock-Pontiac alum out-of-box shape Stan
Interesting that's what i thought but the ave csa is showing equal to or a little less than the min csa i measured.
Are you working with stock or worked heads? If the heads have been worked on. Is it possible that the intake side has been milled? Stan
Does it match the flow sheet?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
EHTTFMF
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Thanks for the port length info |
Flow sheet isnt helpful with this
What you need to do is get ahold of your buddy Paul K and have him weld some of these thingies in there. That way you can have them any length you want. Call it Paul K,s Variable Length Intake Runner Pontiac Victor. Sounds catchy. Maybe he can get as patent for them. This is Pauls actual work BTW |
That added in port divider needs more roof to floor taper to it.
Port of what it does it to even out the tuned lenght disparity between the roof and the floor of the runners and the floor is short lenght wise by by the width / diameter of the Intake valve or atleast the width of the throat in the valve bowl. |
