#121
Back in like ‘97 or ‘98 in the same car I race today
Ys 400 .035 over 407” 2 bolt mains w studs Stock crank Brooks aluminum rods Arias 13-1 pistons #62’s ferrera 2.11/1.77valves home ported x crossover filled Crane gold rockers Isky.648/.648 280/288 on a 108 roller cam Isky roller lifters E torker 2 intake 750 divinci carb Home made crank trigger First ever Langer pan 3-vane vacuum pump T-400 trans Ptc 10” converter 10.59@125 |
#122
Nothing crazy but late 90s 66 lemans. 435in with home ported 48 heads. Cast pistons and stock rods. Used solid lifter flat tappet of unknown specs. Torker1 850 carb. 3400lbs 11.18 around 120ish if I remember right.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#124
Thanks. What did the car weigh with you? Stan
#125
Stan
#126
I honestly don’t remember. Maybe around 3250-3300? Sheet metal was all factory except a glass hood and front bumper. Interior was all stock except rear seats removed and 2 plastic front race seats. Aero space brakes all 4 corners, bogart rims, 28x10.5 et street rear tires. Stock fuel tank replaced with a 8-gallon or so fuel cell. 200 pound driver. You have some ss’ers running bottom 9’s w iron heads now.
#127
Race weight.
#128
Ted |
#129
No idea. I don't remember who the owner of the 455 was. We had installed the 400 into the 70 T/A about three months prior to the article coming out. Pete wanted to surprise Kiel and he did. Kiel got the magazine in the mail and read the article and was totally blown away!
The Following User Says Thank You to 455dude For This Useful Post: | ||
#131
The small engine in that article is different than the spec I have. CR, head cfm, and cam specs are 3 things that jump out at me. Stan
#132
You are correct. After the first post, I decides to dig out the magazine article and check how good my memory was. Although close, I was a little off, and that is why I posted the article to correct my errors.
Ted |
#133
1970 455 .035 over, 1968 96 heads, 1968 Qjet intake, 1968 Qjet by cliff, 582hp 591tq 110 octane fuel, on KRE engine dyno.
#134
Thank you everyone for your information. I believe I have added it all to the list. If I have missed anything, typed something in wrong, or you would like anything updated please let me know.
PMD Heads and Block List. http://www.magneticlynx.com/carfor/pont_pmd.htm Stan
#135
Maybe making this list will motivate some people to break out the old parts and put them back to work.
Thread Tools | |
Display Modes | |
