Old 07-18-2020, 12:18 AM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Vacuum advance removal
I need to remove my vacuum advance from my 77 lemans with a 350 olds. I need to remove it get my distributor timing right.
Old 07-18-2020, 10:35 AM
"QUICK-SILVER" "QUICK-SILVER" is online now
You don't take vacuum advance off to set ignition timing. You pull and reclock the distributor if cam timing is right.
Post #9 here
https://forums.maxperformanceinc.com...46#post6144446
Clay
Old 07-18-2020, 11:56 AM
Post #9 here
Clay
How do you restab the distributor?
Old 07-24-2020, 01:06 AM
Brian Baker's Avatar
Before we get any deeper into this conversation, what exactly is the problem you are having with setting the timing?
Old 07-24-2020, 02:52 PM
Well don't worry about it right now, I'm currently doing the starter on my lemans cause as I crawled under to get a little more slack for my battery cable. (Cause woo sparks are scary.) I could almost unscrew where the cable goes from the starter itself
Sent from my SM-S111DL using Tapatalk
Old 07-25-2020, 01:51 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
There is no reason I can think of to remove the vacuum advance. Just remove the vacuum line attached to it and plug the hose so you don't have a vacuum leak.
Thread Tools
Display Modes
