Discs for a 61 ventura
Planning on using 15” spiders and want front discs. Is there a conversion that allows factory spindles to be used?
Try Scarebird: https://scarebird.com/index.php?rout...product_id=231
Another option is Master Power Brakes: https://www.mpbrakes.com/front-brake...1961-front.asp |
THANKS!!! You guys are all over this!!!!!
The Scare Bird disc brake bracket set up is very good. I tried it twice and get excellent results..
Make sure you use a Metering valve on the front line and a adjustable Proportion valve on the rear line.. |
Does it use the stock drum brake spindles?
Yes.
