SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-04-2020, 08:26 AM
chuckies76ta's Avatar
Default Carrillo Custom Pistons
Brand new set of Carrillo Pistons, pins, rings. Were bought for a 505 cu.in IA2 block and not used.
$2500 Can. plus shipping.
https://www.kijiji.ca/v-engines-and-...ons/1515376184
Old 09-04-2020, 09:48 AM
2500.00 for a set of pistons?
Old 09-04-2020, 11:38 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Canada dollars
Go fast, see Elvis!
Old 09-04-2020, 11:59 AM
mysticmissle's Avatar
Billet?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 09-04-2020, 02:23 PM
Dragncar Dragncar is offline
1913.69 $, US Dollars
Old 09-05-2020, 08:50 AM
Canada dollars
Yes Canadian dollars.
Old 09-05-2020, 08:51 AM
Yes. Thanks
Old 09-05-2020, 08:54 AM
Originally Posted by mysticmissle View Post
Billet?
Yes. Thank you
Old 09-08-2020, 05:50 AM
Box contains Pistons, Ring Pack, Piston Pins, Spiral Locks. Thank you.
Old 09-11-2020, 06:20 AM
Billet?
Location is Alberta, Canada.
Price drop. $2000 Canadian or $1500 U.S. plus shipping.
Your CP pistons are a high strength aluminum forging design. Says Bullet Series Pistons on build sheet.
Charles
Old 09-11-2020, 06:45 AM
Pics of pistons.
ID:	549224   Click image for larger version
ID:	549225   Click image for larger version
ID:	549226   Click image for larger version
ID:	549227   Click image for larger version
Old 09-11-2020, 11:23 AM
Very Interested in the Carrillo Pistons.
One question:
Can you tell me why the spec sheet says that the block deck height is 10.250 vs the actual IA-2 or production block deck height which is lower.
Typically, even on the IA-2 blocks a .005" clean-up on the deck would drop that number an additional amount vs the assumed block deck height on the sheet 10.250". PM me with your reply if you want.
Tom Vaught
Old 09-11-2020, 01:27 PM
PM sent. Thank you
Old 09-15-2020, 04:58 PM
Pistons are still available to PY members as I went with a different plan.
These pistons are very nice pieces by the way and similar to what I decided to order vs buy his excellent parts.
Old 09-15-2020, 05:03 PM
Not a problem Tom. Thanks
Old 09-24-2020, 08:06 AM
These were purchased for a 505 cu in IA2 block for 10.5-1 compression with approx a 74 cc head. We decided to go to 11.1 c/r and 86 cc heads.
Charles
Old 02-23-2021, 09:04 AM
Still have these.
Old 02-23-2021, 04:17 PM
68hotbird 68hotbird is offline
Default pistons
These pistons would work for my build but someone enlighten me on the price. Ive bought alot of pistons custom and never paid over about $1100 for radical custom pieces.
Old 02-23-2021, 04:51 PM
I think my builder got a little overzealous on the price. I’ll do my best to work with you on them if your interested.
Charles
Old 03-04-2022, 08:06 AM
Price drop to $1200 US plus ship. Thanks
