Old 01-18-2024, 12:19 PM
Joe37 Joe37 is offline
Default Thermostat valve
Where are all the thermostat valves? I need ( want ) one for a '65.
Is there any after market pieces?
Old 01-18-2024, 02:13 PM
Kenth's Avatar
Kenth Kenth is offline
I guess most of them has eroded beyond usage. Mine did.
Thinking of making a hole with 3/8"-18 dryseal thread in a cover plate and mount a ported thermal vacuum switch, like SMP PVS7 or similar, in it.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-18-2024, 05:52 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
This guy?
The one on my ‘66 YR just needed a thorough cleaning inside and it works as intended.
Every once in a while they show up online.
ID:	626752   Click image for larger version
ID:	626753   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 01-18-2024, 08:20 PM
They must have been pretty crappy switches, dad said this one quite a long time ago.
Old 01-19-2024, 05:23 PM
Dick Boneske's Avatar
I have quite a few, none functional. If you want a cosmetically nice one, DM me.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-19-2024, 08:18 PM
Thanks, mine is really nice looking, just nothing inside it. It's going to get epoxy filled and bolted back on with the lines still running to it. Functional, yet not like it was designed.
Old 01-19-2024, 08:57 PM
carbking's Avatar
carbking carbking is offline
A good machinist can make one, so can an amateur machinst (me, many years ago).
Jon
Old 01-19-2024, 11:03 PM
Dad said it quit many years ago, he drove the car without working so it wasn't a big deal. I'm just fixing them up so he can look at.
Old 01-20-2024, 06:28 AM
Kenth's Avatar
Wouldn´t this eliminate opening of the secondary carbs?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-20-2024, 09:58 AM
NO, you leave enough open so the vacuum passes right through both ports. The epoxy is just to insure no coolant gets through. Dad said that was the problem with his, coolant seeped in and gummed up the works, finally corroding it enough it seized up.
Old 01-20-2024, 01:03 PM
Kenth's Avatar
Sounds like a disaster waiting to happen.
I´m running mine with the thermal-valve bypassed and a cover plate were it sat.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-22-2024, 07:01 PM
This is nothing more then a cover plate with two hose ports. We want to look correct.
