Old 01-27-2023, 08:10 PM
HO LEMANS's Avatar
HO LEMANS HO LEMANS is offline
Default Rear Sway bar location
I realize they didn't put the rear sway bars on until 70' but I would like to add one to my 69' 350 H.O. Lemans and I was wondering if there is a template available for locating the placement of the holes in the trailing arms so I can put them in before I weld in the inserts, or if someone would be so kind as to let me know what those measurements should be it would be Greatly appreciated.
Thank you
NEVER DRINK DOWN STREAM FROM THE HERD
Old 01-27-2023, 08:54 PM
thepontiacman's Avatar
Lower boxed control arms were used from factory to bolt the swaybar to. 2 bolts per side
I should have some boxed arms to measure.
Old 01-27-2023, 09:56 PM
HO LEMANS's Avatar
that would be great! thank you!!
Old 01-28-2023, 03:02 PM
Hope this helps
Sent from my Moto Z3 Play using Tapatalk
Old 01-28-2023, 05:05 PM
Verdoro 68's Avatar
The instructions for the Summit rear sway bar have measurements.
https://static.summitracing.com/glob...sum-720208.pdf
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 01-28-2023, 05:16 PM
HO LEMANS's Avatar
[QUOTE=thepontiacman;6403904]Hope this helps
indeed it does and I thank you very much!!
Old 01-28-2023, 05:21 PM
HO LEMANS's Avatar
[QUOTE=Verdoro 68;6403928]The instructions for the Summit rear sway bar have measurements.
Thank you Verdoro 68 (Verdoro Green hands down my favorite Pontiac color!! ) for the heads up on that I will save that in my files
