http://www.machdevelopment.com/album...775/527566.htm |
The Following 2 Users Say Thank You to Bruce Meyer For This Useful Post: | ||
I use a 160°. Works for me. I don’t overheat up at Dreamcruise
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
160 in all my Pontiacs for the past 45 years. No problems.
Jeff |
The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
160° thermo was part of the Royal Treatment.
If I be were driving my car daily in cold climate winters, I might use a 180-195
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
What should be taken into consideration when worried about viscosity is the pour ratings. Basically an indication of it's flow abilities at cold temps. Many "good" 20-50 oils today have excellent pour qualities, some are even better than the cheaper 10-30 oils on the market that many people are using. Ponder that for a second. |
I use Brad Penn 20W50 in mine. Any idea what other oils with same viscosity have similar pour ratings?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Let me see if I can find the chart and I'll post it. There are quite a few that have good pour ratings.
Here's an older chart. I'll see if I can find a more current one that has more oils tested. I think specific brand oils should have a chart of their own as well. But this gives an idea of the vastly different pour points, even among the same viscosities. Years ago I would have never thought they would be so different.
https://mcgeerf.tripod.com/americans...coil/id17.html Will, isn't Brad Penn now Penn Grade? Or is it the other way around? Pretty sure that ranks right up there with other high end oils like Amsoil, Royal Purple, Red Line, Mobile, etc.... |
Oops - you’re right- I meant Penn Grade but in my head it’s still Brad Penn
Thanks for the link!
I do the same thing, I can never remember lol
https://penngrade1.com/wp-content/up...-Oils-2022.pdf |
Is there preferred brand of thermostat?
I used to run a 160, but with the factory top rad support cover I run these. No need for air bleed unless your hose goes down hill off the neck. YES you Can get these still, GM Ran these in S-10's as I recall.
Not sure this will pacify the "boil" the oil folks though LOL.
Not everyone have an engine built by your machinist, i´m sure he did a good job for your racing engine. Also, if you haven´t noticed, this is the street section and lots of folks here run with factory clearances and where 20w50 and 160°F thermostat is less desirable. This is, among other things, what the article is about. FWIW |
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
#38
Just answering the OP's question - 195 in Pontiac and both Fords, and everything else I have owned for the last 30 years. No issues. And better fuel economy than most report.
Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
#39
I can give a tinkers damn what the factory did! I have been running 160 for decades and not changing!FWIW,Tom
#40
180 with functioning factory air. No problems at all, including sitting in traffic with air on. Recored factory radiator too. Using a high flow thermostat.
"I know just enough to keep me here, but not enough to get me out" |
