Old 01-04-2023, 03:32 PM
Formulabruce's Avatar
Default Buddies 70 Formula
Been working on this 1970 Numbers car for a few years. Finally got in the resto shop after a 1.5 year wait. The car is getting its second coat of high build primer today, then will sit for a month For shrinkage. We will get just the painted shell back, then after engine and trans, will bring it back for final Assy and cut and buff. He bought a Silversport Tremec 5 speed to use with his 3.31 12 bolt. We test fitted it. Factory shifter handle..No MODS to tunnel, Factory clutch too. ( m22 clutch disc). Nothing hits the tunnel. Its a blue car and will be very nice this summer. ( truck in back is a 34 chevy)
The Following 2 Users Say Thank You to Formulabruce For This Useful Post:
Old 01-04-2023, 04:13 PM
jhein's Avatar
jhein jhein is offline
Hard to beat a 70 Formula.. Can't wait to see the progress and see it done.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 01-04-2023, 05:31 PM
I usually get shrinkage when in the pool...
That car is going to be amazing...very exciting
Old 01-04-2023, 08:32 PM
grd777 grd777 is offline
nice gaps and line ,hope to get mine o this point
The Following User Says Thank You to grd777 For This Useful Post:
Old 01-04-2023, 08:55 PM
Looks great!
Old 01-04-2023, 09:42 PM
70TA-RAIII 70TA-RAIII is offline
Looks like it's going to be a nice one! Looking forward to progress pictures as it moves along.
John
70 TA RAIII M20 05D
70 TA RAIII M20 06B
The Following User Says Thank You to 70TA-RAIII For This Useful Post:
Old 01-04-2023, 09:48 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
The work you guys have been doing on that Formula is very impressive. I can't wait to see it in person!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 01-31-2023, 01:10 PM
Got the new Silversport Temec installed on the engine after some alignment checking.
Next is the high heat coated RA manifolds for the 12's.
Original M-20 is rebuilt in cold storage.
He is using his stock Flywheel and M22 clutch. All manual and stock clutch set up.
ID:	606406   Click image for larger version
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 01-31-2023, 04:42 PM
Ramairnacho Ramairnacho is offline
Looks great. I never new that a bellhousing mounting surface needed to be zero.
Old 01-31-2023, 10:06 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
What is the ball park price on the Silver Sport tremec that uses the stock parts?
I built it one piece at a time and it cost me more than a dime.
Old 02-01-2023, 02:07 AM
I can find out, but its now 1 year old. My guess is $3500 ALL IN ( drive shaft , cross member included) Only thing to buy is a M22 clutch disc, a METAL fine spline M22 clutch tool, and Hurst Shift handle so it all looks stock inside.
We had this tranny in his car for a test fit with my 1970 400 last summer. It was close, but no hitting .
Old 02-01-2023, 02:11 AM
For the Tremec 5 and 6 speeds it does. For the factory 3 or 4 speed it is close enough as the input shaft has some play.
This one was off center by Under .002. Its going to be fine.
Th350 , TH400 doesn't matter.
