Old 01-16-2023, 08:40 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Default 73 TA, Auto or manual
Hi there, just picked up a 73 TA, is there any asy way to tell if it was a factory 4 speed, or auto car.
Its a disassembled project, and has a normal auto shifter, but there is a 4 speed hump in front thats blocked off. The auto console is also fiberglass, so possibly a repreoduction, ??
VIN is 2V87Y3N10XXXX. Not an X in position 5 unfortunately lol.
Cheers
Working on going faster (and now staying dry at the same time !!)
Old 01-16-2023, 09:35 PM
Formulabruce's Avatar
get a PHS. You can get the main sheet emailed back to you once you pay.
Old 01-16-2023, 09:55 PM
455-4+1's Avatar
Yep that's in the plan.
Does that still apply for cars that may have been sold new outside of USA.
This has been in New Zeland from very early on, and possibly sold here new
Old 01-16-2023, 09:57 PM
455-4+1's Avatar
Not definitive I know, but it looks to have a lot of original 4 speed hardware attached. Fingers crossed
ID:	605343   Click image for larger version
ID:	605344   Click image for larger version
ID:	605345   Click image for larger version
ID:	605346   Click image for larger version
Old 01-16-2023, 10:17 PM
Held for Ransom's Avatar
PHS will not tell you your TA came with manual or auto. Clues do indicate a manual trans. vehicle. May have been a no console car, in which case having the correct steering column will also tell something.
So long, farewell.
Old 01-16-2023, 10:23 PM
That hump and hump cover is Weird .
Was it converted to Right Hand Drive also ?
PHS on a 70-73 TA won't tell if 4 speed or Auto
Was no cost alternate.
If it came back as no console , that could mean 4 speed - or Auto on the Column.
If it was ordered new with a console, back to ground zero again.
But yours probably was factory 4speed with the clues you have.
Old 01-16-2023, 10:26 PM
Yes it will still be available as an export invoice.
Congrats on your new TA !
Old 01-17-2023, 12:09 AM
455-4+1's Avatar
Thanks all
I have seen some examples on the PHS site that showed original invoice which indicated if a car was manual or not ?. Was hoping that would be the case here ?
Maybe not on 70-73 as mentioned due to no cost difference ?
The car is still LHD (allowed here in NZ) and was registered in 73 or 74, will need to check. The cover on the steel 4 speed hump is just blocked off, and the retainer looks exactly the same as the boot retainer on my 76 manual TA. Guessing it was just blocked off and the retainer hacked to fit an auto cable. The auto shifter mounting definitely does not look stock.
Heres hoping as I have a correct Muncie, bellhousing and everything except the cross bar to convert it back.
Old 01-17-2023, 12:57 AM
If the '73 was optioned w a tilt column, & still has it, feel free & check the colored pick tag (decal) on the column tube & PM me. That decal will be different than one with an automatic, I can check the my '73's man trans tilt. As a manual trans car, should also have a neutral safety switch.
Old 01-17-2023, 02:03 AM
I have seen some examples on the PHS site ....
Exactly.
The invoices only show content that had a cost.
On the ones you viewed , they had a cost involved with their transmissions.
70-73 TA did not have a cost for the choice , so it doesn't show up on invoices.
I have owned 1970 and 1973 models , it is not on the invoices.
Old 01-17-2023, 10:53 AM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Congrats on that pickup - I saw that on Facebook Marketplace and posted a link to it on the 'Pontiacs Downunder' group. Certainly a major undertaking, but looked like a good score. I ran the plate through Carjam when it was first listed and it looked like NZ new (or very early registration).
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
Old 01-17-2023, 01:37 PM
Auto on column was still being built... just tossing that out there..
Old 01-17-2023, 02:11 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
Besides the steering column itself, wasn't the under dash harness also different for auto vs manual, especially concerning the fasten seat belt warning? I need to look back at my schematics at home, but I recall the manual cars of late 72 and 73 had an extra relay to integrate with the parking brake switch vs the auto utilizing the neutral safety switch for the fasen seatbelt buzzer.
I built it one piece at a time and it cost me more than a dime.
Old 01-18-2023, 03:32 AM
455-4+1's Avatar
I hope its congratulations lol, yes a lot of work !!
But it will be a long term project. All of the required rear sheet metal is there and the floors are in surprisingly good shape, just the usual boot, rear quarters etc.
Rear frame rails are still good which is a bonus. Its certainly not an Arizona car lol.
There was alot of NOS and reproduction stuff as well, like lights, surrounds, fender flares etc etc.
Yep its been in NZ most of its life. Interesting enough the 1st NZ owner only lived about 1/4 mile from where I was born and lived at the time, I was 2 yrs old in 1973 !!!!
Old 01-18-2023, 03:35 AM
455-4+1's Avatar
Originally Posted by fbody_mike View Post
Besides the steering column itself, wasn't the under dash harness also different for auto vs manual, especially concerning the fasten seat belt warning? I need to look back at my schematics at home, but I recall the manual cars of late 72 and 73 had an extra relay to integrate with the parking brake switch vs the auto utilizing the neutral safety switch for the fasten seatbelt buzzer.
From memory there is an extra relay under dash which I have never seen before, I will need to climb under and look at the column, and also the markings, pink tag etc etc .
It is encouraging that the majority of the 4 speed stuff is attached to the frame, the clutch rod boot has been there, and the 4speed hump is intact with factory sound deadening cut around it etc
Edit,
Column is non tilt, there is the normal ? arc shaped switch on the columns with green / pink / purple / purple wires, as well as the opaque white plunger style in line with the clutch pedal with 2x purple wires.
I am guessing this is the neutral safety switch?
Old 01-18-2023, 06:47 AM
Norwood's Avatar
Norwood Norwood is offline
I’d say looking at the posted pictures that you can take it to the bank it’s originally a 4 speed
The Following User Says Thank You to Norwood For This Useful Post:
Old 01-18-2023, 01:34 PM
Purple wires under dash went to CLUTCH pedal. To run an auto, they may be spliced together. They are thicker than other wires.
My window sticker for a 71 had paint color and m20 at very bottom of the window sticker ( from PHS also).
Old 01-18-2023, 05:01 PM
455-4+1's Avatar
Yep your right, the 2x purple thicker wires go to clutch pedal switch, as seen goin into black connector above switch in photo.
Thanks for the info everyone.
ID:	605453   Click image for larger version
Old 01-18-2023, 07:09 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Do you have the original engine block with the VIN stamp? If so, block code will tell you.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 01-19-2023, 05:26 AM
455-4+1's Avatar
Nope, unfortunately that's long gone
