Flat tappet cam failure
Let’s talk about this phenomenon a minute. As many of you know my block failed and took the roller cam with it but thank god took nothing else with it. I have other things I need to do to “finish the car” so I couldn’t put 1500 in a new setup right now so I went HFT. Butler told me they don’t sell their engines with flat tappet anymore because of too many failures. I then contacted Crower because of my concerns and desire to run the 60919. They stated while failures did occur it was more like 20% and the returns they received were from obvious poor break in most of the time. Wayne Sless SR. Is building my short block this time and he is the crew chief of a few cars here at the Ware Shoals 8th mile track and he says with props break in I have no worries. The 3 sets to make a perfect set was a little of a misnomer. When pushed Wayne said he has a spec range he personally likes to see not that these others were junk. So Wayne is doing all short block assembly, the only thing I am doing is sealing it up and putting accessories on. I hope to be rolling in another 4/5 weeks. Here is my plan I’m gonna cuss and say I have built 3 Chevrolets before so this is the plan I intend to follow. Hook everything up and check for leaks as best I can before starting so we don’t have to shut it down. Fill with Lucas 30w break in, 6 quarts. No additional additives unless you have input. Turn engine over slowly 3 times or so while half inch drill builds pressure..once I have pressure I am going to use the mustard bottle trick for the fuel bowls y’all recommended. Use a hand pump to pull some fuel up to the mechanical pump so it isn’t trying to pull from the tank dry. Drop in distributor with cylinder/balancer on 0* and then trim the rotor back approximately 12 degreaser.. hook up choke, pat accelerator once as always and hit it. When it fires I will alternate between 1800/2500 for 20 minutes with hose standing by to cool down radiator so I don’t have to shut if off. After 20 mins let it cool down, drain oil cut open filter and look for glitter.. if I see none I run another 500 miles of Lucas break in and then if that’s clear then I’m good. Anyone add anything?
The Following 2 Users Say Thank You to 64speed For This Useful Post: | ||
Remove inner springs to reduce the open pressure. Mike successfully broke in the SFT cam in his 421 that way and we're going to do the same with my road race engine.
Eric
The Following 2 Users Say Thank You to Elarson For This Useful Post: | ||
I put the balancer at 16 degrees BTDC and the distributor rotor on #1 terminal, works well. Start with a known carb and fill the bowl with gas before cranking. Have your timing light hooked up and ready and have your wrench ready to loosen and tighten the distributor bolt. I jack up the front end slightly to make sure all air in the heads come out and initially fill with distilled water. Have another person there to help.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
I will have about 5 looky Lou’s standing around
The Following User Says Thank You to 64speed For This Useful Post: | ||
Leave inner Springs (is a reasonable cam-spring combo), do as you posted, yet i prefer to drive the vehicle on a highway, up then back for the 25 minutes for the many reasons of proper cooling, CYL ring loading, clean air, no fouling, and feeling the joy of success.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
The springs were spec’d by crower and Butler agreed. Of course I have no way to do that in the car without a tremendous amount of labor. It’s a perfect scenario I agree but it’s just not feasible for me. My surgery is on my stomach and I will be having trouble doing all this as it is let alone 16 springs in car
I'll just add to post #3, leave the thermostat housing off and watch the cross over while filling with whatever you use for coolant. Keep filling rad a bit and it will raise level in crossover. Reinstall thermostat housing. That way all the air is out from the heads for sure. I'm with AG on the 16 degrees. Make sure to always run an oil with zinc and phosphorus for maximum protection. https://lucasoil.com/products/hot-rods-classic-cars Wishing you success.. Oh and no synthetic oils for awhile. Put some miles on it.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
Find somebody to pull the inner springs 💯 for break in. I'm doing a 2802 in a seasoned engine and I've already left the inners out. Even tho the 2802 and the 68404 spring is a mild combo, I'm still leaving the inners out for the break in.
2000-3000 RPM for 3 rounds of 10-15 minutes each.
The Following User Says Thank You to chiphead For This Useful Post: | ||
run water only until you know everything is good.Tom
The Following 4 Users Say Thank You to tom s For This Useful Post: | ||
Yep... I did this when breaking in my solid flat tappet cam.. So far so good.. This thing gets POUNDED ON every time I take it out and several hundred dragstrip passes since putting it together. Be sure to run high Zinc oil.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
Rotating the crank three times is excessive and will scrape off the moly break in paste from cam. Instead, spin oil pump CCW as indicated and look for oil pressure on gauge. What some also look for is oil coming out of the pushrods and then rotate crank to reposition the lifters. This can be accomplished a 1/4 rotation at a time but not three full rotations.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Well after a long talk with the machinist and some measuring because of the hydroboost etc I don’t have enough room to have an in car spring changer. In that my decision has been made. I’m taking my hand out of it totally. Wayne is just gonna build the whole damn engine. Only thing I gotta do is pay another few hundred dollars and he’s gonna finish it out and break it in.
While to much spring pressure can be a problem. You need to know how much pressure only the outer spring has because to little spring pressure can also be a problem.
This a quote of a post by Mike Jones. Quote:
FWIW, since 2015, I've broken in 4 sets of FTHL's without removing the inner springs. 2 HyLift Johnsons, 1 Lunati set with a VooDoo 703 and an NOS set of TRW lifters from the mid 80's (quietest of the bunch BTW). No failures, Comp Cam break in oil w/ JGR Driven assembly grease & hi zinc oil after break in. Your mileage may vary.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
I pull the inner springs out of all the flat tappet cam engines I build
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
The Following User Says Thank You to Gach For This Useful Post: | ||
For the record, i have not given a rats care about Zddp or zinc in my oil. If zinc was such a big help, cam & lifter suppliers would have galvanized the wear surfaces. Alot cheaper so sit down and keep quiet about zinc additives being a big help.
Friction is needed to get lifter rotation, however it gets achieved. Parkerizing the cam has been the 1st line of defense. Lifter surface shape for sure, but lifter surface lacks friction. Go figure how to attain good (best) lifter spin. |
OK, is it just marketing hype ???
"Lucas Zinc Additive protects camshaft lifters and valve train during break-in period of motors. It is excellent for flat tappet camshafts during break-in or as an additive to any motor oil to prevent premature wear. " And presented for interest..... Camshaft Break-In Guide - How To Break In That Flat-Tappet Cam https://www.motortrend.com/how-to/cc...reak-in-guide/ From it... "This led us to pay more attention to the details required to make a flat-tappet camshaft engine live these days, because lubricants are changing faster than Charlie Sheen rants on TMZ. This story is as much about lubricants and what works and what doesn't as it is about camshafts and lifters." .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-19-2023 at 08:39 PM. |
The Following 2 Users Say Thank You to Steve C. For This Useful Post: | ||
I used 1.33 SBF break in rockers on the dyno for my last HFT. Needed shorter pushrods.
