What thermostat to use, 180 or 195 ?
What temperature thermostat is every using in their 1960's and 1970's street driven Pontiacs ?
I use a 180 in the 37 in my signature.
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 77 Grand Prix base model, 350 pontiac 97 F250 7.3 turbo diesel 85 CJ7 Laredo 65 Impala SS 396, 4 spd, A/C. |
The Following User Says Thank You to moneypit For This Useful Post: | ||
180. Whatever you decide test in a pot of go water first to learn where it opens- some open 10-15 degrees past the rating
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
The Following User Says Thank You to grivera For This Useful Post: | ||
With real gas, a 180. With the e10 piss, a 160. Lots of issues down here about fuel boiling out of the vent tubes. So, I try to keep the engine, under hood air, carb as cool as possible.
The Following User Says Thank You to PunchT37 For This Useful Post: | ||
IMO, a 195 is too hot for an engine with a carburetor, especially running E10. 160-180, Trial and error. A really good radiator and fan will keep a 160 thermostat engine running around 170. About 190 with a 180 thermostat. If the engine runs good with a 180 thermostat you will get slightly better gas mileage and keep the spark plugs cleaner at long idle/low speed driving.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
180 and a good cooling system has worked for me (clutch fan, 4 core copper or 2 Core alluminum radiator and proper tune.)
195 you'll probably fight Detonation.
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
The Following User Says Thank You to 74Grandville For This Useful Post: | ||
I use a 160 in everything. Which means typically they'll run in the 170 range on a really hot day, which helps to keep me out of detonation and away from vapor lock issues with todays gas.
On a cooler day, say 70 degrees or below, I generally see it operate closer to the thermostat rating. |
The Following 3 Users Say Thank You to Formulajones For This Useful Post: | ||
I run a 160 in everything, and drill a small hole in the base of them to help bleed air/prevent air pockets.
The Following 2 Users Say Thank You to 72projectbird For This Useful Post: | ||
195° F, 10w30 mineral engine oil and 50/50 glykol/water, just what the service manual calls for. Not an issue in 25+ years.
Note: Too low engine operating temperature increases wear and looses power. FWIW |
The Following User Says Thank You to Kenth For This Useful Post: | ||
I haven't found that last statement to be true......with my stuff anyway.
I've been running these 160 stats in several of the classics here for going on 35-40 years. I've never had any excessive wear problems. In fact 2 of them are daily drivers that have seen over 100k miles combined in the last 5-6 years and they still perform perfectly At the track we've found our best ET and MPH when the car is cooled to about 150 to start the run and generally is around 165-170 when finished. Hotter just slows the cars down so I don't see the loss of power with the cooler temps either. |
The Following 4 Users Say Thank You to Formulajones For This Useful Post: | ||
If ones car is strictly a street driven car and for some reason the owner likes to drive it in cold winter conditions then I would put in a 180 so the heater would work better.
http://www.machdevelopment.com/album...775/527566.htm |
The Following 2 Users Say Thank You to Bruce Meyer For This Useful Post: | ||
Mostly, you will get to where you`re going. Coming back? That`s another story. [Hot soak] |
160 degree thermostat for years.
The Following User Says Thank You to ta man For This Useful Post: | ||
I've run my bird the most there, and in early rounds with enough cool down time I can run right on my dial where the car has run it's best time, but once we get down to the last 6 or 8 cars and time shortens between rounds I have to dial it back from 13.10's to 13.30's because it just won't run the number when the engine gets that hot. If you use the typical drag strip slide rule for HP, that's a significant drop when the engine heats up. I always have very similar results with the other cars as well. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
160 with distilled water and a bottle of water wetter.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
When (and this may take a while) I get my car to a street reliable setup (a working PCV system, Vacuum advance, mechanical fuel pump with a regulator, electric fan vs clutch fan setup sorted out) I'm going to experiment with a 180 and 190 degree thermostat and see which one works better. Thermostats arent that expensive so I'm just going to try it out.
1968 - Pontiac GTO |
I’ve also found that 160 works best for all around drivability.
The other part of the question is what style of thermostat is everyone using?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
Back in the 60s, Pennsylvania winters I tried 195. Then changed in summer to 160. I found out for 'myself'160 seems to be the best all around. Performance in spring and summer,fall and heat for winter. That's me.
160°F is 71°C.
Hope you´re not running 20w50 engine oil. Reading this paper may be an eyeopener: https://www.widman.biz/uploads/Corvair_oil.pdf FWIW Last edited by Kenth; 01-27-2023 at 02:57 PM. |
I like to have a stock of small parts like T-stats, housing gaskets, clamps etc etc
The Following User Says Thank You to 72projectbird For This Useful Post: | ||
Thread Tools | |
Display Modes | |
