Old 01-26-2023, 10:23 PM
grd777 grd777 is offline
Default am i getting to picky on my car
trying to get the rear spoiler to fit better ,or is this the way Pontiac did it back in the day
ID:	606099   Click image for larger version
ID:	606100   Click image for larger version
Old 01-27-2023, 02:21 PM
Formulabruce's Avatar
Maybe enlarge the mounting holes for the caps. You can also try different end caps. You will be surprised how different the same end caps fit. Just aligned mine before tearing it all apart.you can sand the inside of the end caps to center section to get it closer.
ID:	606127   Click image for larger version
Old 01-27-2023, 05:57 PM
i did make a bigger hole ,i will try to grind them and see . your sure do fit nice
Old 01-27-2023, 07:33 PM
muscle_collector's Avatar
if you think they were aligned from the factory you are dreaming. bought trans ams new in the 70's and 80's. nothing lined up, decals crooked, exhaust tips pointing one way and another on the other side, runs in paint, carpet cut too short, doors were extremely friendly as they all had waves in them, i could go on and on. but i still loved them like no other.
The Following 3 Users Say Thank You to muscle_collector For This Useful Post:
Old 01-27-2023, 07:50 PM
Having been there and seen the second gens new, I agree 100 % with
Muscle_collector
Old 01-27-2023, 11:03 PM
As others have noted... fit/finish varied wildly on these cars.
To get the 3-piece spoiler looking really right on most cars takes a level of finesse that wasn't in the cards at the rate those cars were built on the assembly line (probably about one a minute).
No reason to settle for that now, though.
You may need to do some or all of enlarging the holes to adjust positions of pieces, sanding, and maybe even a bit of body filler to get them right.
Old 01-28-2023, 12:49 AM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
After I get the top line straight across it’s a matter of getting the gaps correct. I’ll sand and fill. But don’t use ordinary filler. These are made of SMC, so use Evercoat Vette Fill. It will adhere much better than bondo.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
Old 01-28-2023, 07:23 AM
yes i can starting to see this as i am trying to get all the panels to fit better. thanks for the input . and i love these car too
Old 01-28-2023, 11:54 AM
Big Bear's Avatar
Big Bear Big Bear is offline
After you get it fitting like you want and painted, then installing the weatherstrip throws it out of wack again. Going through that this week. Adjusted the lid lower to try and compress the weatherstrip. Will leave it like that for now and see if it settles in.
Old 01-28-2023, 12:43 PM
yes i learned that when i did my last mustang .once the car got painted and i installed the door weather-stripping the door never fitted right
thanks for your input
Old 01-28-2023, 02:11 PM
Many trunk seals are WAY too thick... The only one I know of that is correct is the 1A auto trunk seal. They have a video on a Pontiac installing it.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 01-31-2023, 06:13 PM
unruhjonny's Avatar
this part made me laugh:
... doors were extremely friendly as they all had waves in them,...
I read the first part, momentarily paused "friendly - huh?" - then continued... and laughed and laughed.
I agree, but I also know that if you have the trunk lined nice, that you can absolutely get them better than that.
1970 Formula 400
