Harness/wiper reservoir clips
Hello guys,
Do they reproduce the plastic push type clips for the harness, wiper washer reservoir hose that attaches to inner fenders? I couldn’t save any of them I need 5 Thank you |
I picked mine up at Ames. In their catalogue check under ENGINE COMPARTMENT STRAPS & WIRE RETAINERS.
The ones Ames sell don't work on the Tempests, they are too long. I've not been able to find any myself that work. I just used black zip-ties and install from under the fenders.
I just made some. Cut the strap part from fuel pump diaphram material and can't remember what there called for the button heads. Used to hold papers together.
Here is what my black zip ties look like holding down the wire loom.
That's what I did.
Does anyone have pictures and/or dimensions on these?
Straps
Thank you guys
Those look good as well I will probably do the same or fill original holes and drill for the ones that are available |
Under hood plastic wire straps. '63 Lemans
Those plastic wire retainers are an unusual size. It is made like a strap and both sides have push-barrels that plug into the 2 holes. In all the swap meets I have looked I have seen none that are exact dimensions to the factory plastic.
Peter Serio Owner, Precision Pontiac |
