SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 04-29-2017, 09:36 AM
Jim Mino Jim Mino is offline
Default 1968 Ram Air II Cylinder Heads #96
1968 Ram Air II Cylinder Heads cast #96, matched set with F198 dates, original un-touched intake & exhaust ports, performance 3-angle valve job, machined head and intake surfaces (65.1 cc's min.), all new hardware: Ferrea stainless steel valves, Edelbrock double valve springs (129 lb. seat), Comp Cams 10 degree Chromoly retainers and Super locks, Viton valve seals, 7/16" rocker studs, freeze plugs and heater hose fitting, ready to install (never used) $4300 plus actual shipping
ID:	453355   Click image for larger version
ID:	453356   Click image for larger version
ID:	453357   Click image for larger version
ID:	453358   Click image for larger version
Old 05-17-2019, 04:11 PM
splitknucks51 splitknucks51 is offline
Default 96 heads
Hello my Nate and I am hoping that you still have the 96 head with a date code of 68. I know that this is an older post, but I am in a dire search for some. If you could let me know that would be greatly appreciated.
natebeve@yahoo.com or 801-833-6951
Thanks again,
Nate
Old 05-22-2019, 11:53 AM
Thanks again,
Nate
Hi Nate, those heads were sold. If I come across another set I'll keep you posted.
Thanks,
Jim
