ohc
1967 230 cubic inch sprint 6 complete water pump to tailshaft (3 speed manual) not sure if p.s. setup is correct includes crossmember z bar f body motor mounts and frame perches $800.00 or best offer
Where are you located?
ohc
Maplewood/St Paul,Mn
I sent you a message on this.
Just FYI, I am not sure that is a 230, by the look of the Large HB that as far as I know was only used on the Manual Trans 250 engines.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Sure looks like the larger Sprint HB. We need to know what the block casting number is. There is also a part number cast into the HB that would easy to identify.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
