OBX Headers installed on 64 Tempest
Sold my OBX headers to a friend that was in a bind and needed some. Sent for another set for my car. Anyway, got them installed on his '64 Tempest. The drivers side went right in with no problems. Had a little trouble with the passenger side. It was a little tight on the passenger side, but a little more pre-planning would have helped. I would recommend installing the passenger side first. Keep the motor mount bolt out and raise the motor a little on that side and it should slide right up there. Once they are in they fit really nice. Don't hit anywhere. Here's some pics. The motor is a 455 that he bought off 10second70GP.
More pics.
How do you think they would fit with a Z bar for a stick?
GV OD on the tranny?
x-2 what skip asked? looks real good, im definateley considering some of these over my huslers now
http://performerrpm.myphotoalbum.com/view_album.php? |
x3 on the z bar & how is oil filter access? I see the filter housing is not on the motor yet.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
noticed thos collector flanges........they look pretty solid
Skip,
Not sure on the z-bar, will have to take a look at it. Yes, that's a GV OD. He's going to put an angled oil filter housing on it and it looks like there's plenty of room there. A remote mount could be an option. |
My 65 GTO project will be getting round ports either my RAIVs or some E heads. It is a stick I'd like to keep, but I guess I could always modify a tube or two so I ordered a set.
I have a set of the IA freaking 24 piece early GTO round port headers that look like the are a leak waiting to happen for all the individual tubes.
Skip Fix,
Just wondering if you got your OBX headers and what you think of them? |
Got them Friday. Man they are flat! I was surprised how flat the box was. They look like good quality polished like they are coated. Held them up to a block and looks like good oil filter clearance, not sure the Z bar though. That rear tube may need massaging for a stick.
Also wish the reducers were 3.5-3".
Subscribed!
My project is way off from being together. Still not sure that rear tube may need cutting and moving some.
Anyone tried them on a second gen f body or know if the a body headers or their 67/69 f body headers fit a second gen?
Daan |
Anybody?? will a body headers fit a second gen bird or 67/69 brid headers??
Daan |
Blank1, is the pass side brake line routed in front of the crossmember?
Ebay ad says 3/8" flanges and 1/2" flanges. Which one are they? Collector reducers 3" or 2.5 Thanks, OGR
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Doug headers don't interchange, so these shouldn't either.
Bought a set for my 67 GTO....collectors= 3.5" reducers = 2.5" all flanges=3/8"...very nicely built, cant vouch for install as I have a custom chassis, IAII block, and E-heads. basically for $289, I rolled the dice.....Eric
Just got my set today. I already own 2 sets of Doug's headers at $650 each. They look almost identical. just shinier. It will be several months before I install them on my 70 racecar. We'll see.
Seems too good to be true, and ya' know what they say........
