Backup light switch.
I have a 72 manual trans with 64 tail housing, can I use a 65-67 backup switch? Also the trans has a 72 bellhousing can I use an oem flywheel on my 67 engine.. Not sure if you can mix and match parts. I know this is probably an easy questions for you all, but I need to be certain before I order parts.
Thanks |
IMHO it would be easier with the aftermarket BU LT SW.
It utilizes a plunger rather than the small linkage rod, found on OE SW. If you already have all the OE parts then it's just a matter of setting it up so the function matches the travel of your lever. You might even need to drill the hole for the small link/rod, if your linkage mounting lever/tab doesn't have it. JM2C Cheers
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:18 AM. |
Thank you. I dont have any of the original linkage, so the aftermarket will be perfect.. |
68 parts work great also
heres a couple pics of my 70 m-22 w 68 back up items https://www.gtoforum.com/threads/196...switch.133947/ |
