There just wasn't a picture on your last post, so I was breaking your balls.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
i wont get my block back for a couple of weeks-so i am borrowing toms!!!! to look at anyway.he is supposed to send some pics of his completed engine in the car.i cant wait to check those pics out.and i think you are right-i think you are the one that mentioned putting the block with my top half.so i can blame you for the sky-rocketing price in this already expensive project!! lol
FYI,when the heads are on and the exhaust also you cant see much of the block.Kind of like having a $100 bill in your wallet,cant see it YOU know its there.Tom
kind of like my crank-you cant see that 4.5 inch stroke-but i know its in there.also,dont forget about the timing cover.tom s-the important part-WE KNOW ITS THERE!
here you go!
couple more.REALLY need to clean up the compartment!Tom
Great project, Greg.
The ultimate Pontiac engine with the ultimate Pontiac car....
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
tom-that looks killer!!! i was thinking about clear coating my block to help keep it cleaner looking.only thing i worry about is the clear coat sealing the heat in.what do you guys think?
shouldn't aluminum blocks have screw in core plugs?
Wow!..its great that you guys have the resources to save these mythical pontiac pieces!..greg that is going to be over the top!...please post pics asap...what heads are you going to use?...how about some build info or did I miss that in another post?
Tom S, what do you have that engine in?...I recently found an old HPP magazine with your 303 RA V powered 69 Trans Am featured in it...I had never seen that issue before, only read bits about it here on PY...amazing all the work that went into that build to have an operational 303 short deck street car...enjoyed reading both articles. Quote:
1970 Lemans Sport, PPR 383/4spd. |
that short block is now built as a RA V engine in my 69 royal bobcat clone GTO.It has been in my 69 trans am as a RA V,my 63 lemans as a all alu engine with KRE D ports.It is a 446 CI engine,4.120 by 4.125.Carillo rods and Ross pistons.I also have a 366 303 based engine in a 69 firebird that is going to the header shop fri.Tom
Greg,it cleans up ok with brake cleaner,just have to keep it off painted parts.I have a show in april and will get it done.I drive that car a lot,usually 60-120 miles at a time.I painted all the iron parts black.Tom
tom-i really like the headers on the gto.my alum rav is going to be 4.120 bore.also a steel crowler stroker crank with a 4.5 inch stroke with rav heads,solid roller and factory 4 barrel intake.480 CID 12-1 compression.i am going to paint my heads pontiac metallic blue,the rest will be aluminum.tom,any extra deep pulleys laying around?
rick has been trying to get me to paint the heads to look aluminum.i think it will look good with the blue against the aluminum.thinking about getting aluminum valley pan also.seeing toms engine really gets me fired up!
tom, greg...someday I hope I can see those in person!...but for tonite, I know what I will be dreaming of...RAV blocks...intakes...heads..lol
Tom....you HAVE to post some pics of that Firebird...this is legendary stuff that you must share with us! Is the aluminum block capable of withstanding up to the same forces an Iron block can take?...greg, any special work to the block to handle that stroke and compression?
I dont have any of the deep pulleys except for a aftermarket alt pulley from a HP chevy.You can search posts I started and see the short deck engine in the bird,also the deep alt pulley.I just have not put one on the GTO yet.I was told theses blocks should not be pushed on the HP level.I have kept mine to the 500ish number.Gregs was a raw block that I hope is better than mine was.Tom
whatever happened with the reproducing the 5 heads in aluminum???
#38
Greg, get the aluminum water pump too!
#39
http://forums.maxperformanceinc.com/...=410512&page=5
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#40
kauffmans just made a aluminum rav head out of billet.looks nothing like a factory v head.
