Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
correct!
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
The laptop is buzzing along well. Thanks.
I just got around to powering up the ACER desktop I bought from work. There's no operating system installed? Ouch. SYSTEM PROPERTIES says it has XP Professional version 2002 service pack 3 with a long series of numbers following that. Also, COMPUTER: Intel Pentium 4 CPU 3.40Ghz 3.39 GHz, 504 MB of RAM (looks weak on memory--which kind?). The only programs that come up in the ADD/REMOVE PROGRAMS list is Intel Extreme Graphics 2 Driver and Realtek AC'97 Audio. OPTIONS? I assume that means the Windows XP has been wiped? I can probably get some Windows installed from work if I take it in. Is there another route to consider? Should I mess with changing from XP? Under all 'programs' at the STATE menu I see Windows Messenger, Outlook, MSN, IE, etc. I've got 72 Gigs free space of 74.5G. Wow, I guess it is wiped of Windows. Where would you start? |
If you can see a Start menu, system properties, etc., it sounds like you are looking at Windows. If it runs, leave XP on it or do a clean install of Windows 7 once you max out the RAM.
I would start with a visit to Crucial.com and run the scanner to check what memory will fit in it. I'm guessing you'll need 4 GB of DDR2 800. The Crucial scan will tell you what type memory and how much, and also offer to sell you some of theirs. Sometimes you can find it cheaper online.
That's how weak I am computerologically. Yes, it would be XP I'm seeing if it operates. duh.
KScicutguy suggested I do a fresh install which is what I was going to do with ADD/REMOVE. Thanks for any help. ETA: Crucial says--4 gig of DDR400 for $40 per gig for a Veriton 7600GT--assuming that's what it still is according to the front. I remember this machine chit the bed once and had to go back to the home office. I don't know what was done to it as far as rebuild or what? Per ACER: Veriton 7600GT Series Specifications Part Number: Veriton7600GT Veriton 7600GT Feature Description Processor Intel® Pentium® 4 processor supporting Hyper-Threading Technology, up to 3.40E GHz, 800MHz system bus or 2.8GHz at 533MHz Cache In CPU - Pentium 4, 1MB or 512KB L2 Cache depending on the CPU Memory 512MB DDR 400 SDRAM installed in two (256/256) of four dual-channel memory slots BIOS Acer Flash BIOS Supported Protocols PCI 2.3, APM1.2, DMI 2.3.1, E-IDE, ACPI 2.0, ESCD 1.03, ANSI ATA 3.0, PnP1a, Bootable CD-ROM 1.0, ATAPI System Chipset Intel 865G / ICH5 I/O Controller Hub SMSC LPC47M192 Expansion Slots 3 PCI 2.3 Audio Intel ® ICH5 controller, Embedded AC97 Codec (Sound Blaster® compatible) Speakers Optional on selected models Video Intel® 865G Extreme Graphics 2 on-die graphic solution with DVMT technology and up to 64MB shared video memory Storage 3.5" 1.44MB Floppy Disk Drive CD-ROM Drive, CD-RW Drive or DVD-ROM Drive (selected models) Up to 80GB Hard Disk Drive (selected models) Modem V92, 56K Fax/Modem (selected models) Networking Broadcom® 10/100/1000 Base-T, RJ-45 LAN connector Ports 1 PS2 Keyboard, 1 PS2 Mouse port, Audio line in, line out, headphone out, and 2 Microphone in, 6 USB ports (2 front, 4 rear), 1 Parallel, 1 Serial, 1 RJ-45 Network Interface, 1 VGA, for USBs I have 4 front and 4 rear. The drive says Rewritable Ultra Drive. We run Microstation and AutoCad 2007 on these machines. Last edited by PonchoV8; 11-13-2011 at 11:27 PM. |
This is why I suggested to run the Crucial scan, to find out what is in it now, not what is supposed to be in it originally, maybe still.
Okay, I see the scan this time. Not last night. I accepted the terms of the agreement but it says I have elected not to allow active controls.
I just downloaded the scan: Memory: DDR PC3200 Memory Type: DDR PC3200, DDR (non-ECC) Maximum Memory: 4GB Currently Installed Memory: 512MB Total Memory Slots: 4 Available Memory Slots: 2 256MB DDR PC3200256MB EMPTY EMPTY Last edited by PonchoV8; 11-14-2011 at 02:49 PM. |
Wow
Just down loaded this and it found 153 errors!
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Is Crucial considered the best memory producer? What would be the better names if I don't go with them? BestBuy lists a low price for Crucial, but it's not available.
Anyone have an opinion on a quality maker of memory?
I've never had trouble with any of them. (I've also never benchmarked them to see if any are noticeably faster than the others.) Kingston and Crucial seem to be what I usually end up with, probably only because I see them sold everywhere, so I know I can take 'em back if there's a problem.
Mike |
Makes sense. Buying local. I'll watch for sales.
Thanks, |
x2 on using the program called CrapCleaner. Use this after you reload Windows.
It's amazing how much "crap" comes with a brand new operating system, tons of junk that nobody needs slowing us down!
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
My dell home pc has been down all week, It is saying Microsoft feeds synchroninization has encontered a problemand needs to close.Could ankone please let me know what this is? i can not log on to the net. Thank you for any help Please your friend Randy.
It is part of the Windows RSS platform that monitors RSS feeds you've subscribed to. If you don't use it, you can block it, but would be best to also turn it off:
1. In IE7 click the Tools button and select Internet Options from the pop-up menu. 2. On the Content tab of the Internet Options dialog box, click the Settings button in the Feeds section of the dialog box. 3. In the Feed Settings dialog box, uncheck the "Automatically check feeds for updates" check box. But if you do actually use it (unlikely since you just asked what it is) the real problem is that you can't access the web. If you use Internet Explorer, click on "Tools" and make sure "Work Offline" isn't checked. Otherwise, you may have a virus or malware infection or maybe even a hardware problem such as cables, router, modem, etc. that is preventing internet access.
It is steal down, useing my wifes small laptop.
#38
I ran windows xp today and i am on py now with the big blue box saying the same thing, Do you think it could be my hard drive? TKS
#39
Does any one know what a Microsoft feeds Synchhronization, IS ?THIS is driveing me nutsThe blue box keeps poping up Where i have to read in betwing the lines on PY? Thank you PY and friends.
#40
If you don't use it, you can block it, but would be best to also turn it off: In IE click the Tools button and select Internet Options from the pop-up menu. On the Content tab of the Internet Options dialog box, click the Settings button in the Feeds section of the dialog box. In the Feed Settings dialog box, uncheck the "Automatically check feeds for updates" check box. |
