Old 07-10-2022, 03:09 PM
hutchwareltd's Avatar
hutchwareltd hutchwareltd is offline
Thumbs up
Thank you! Pics are very helpful. Looks like, for whatever reason, a previous owner needed a bigger hole on the passenger side. I also now know where the courtesy lamp goes on an A/C car .
Old 07-10-2022, 06:06 PM
gto4ben gto4ben is offline
I'm not sure if you knew but 8-track equipped cars get two courtesy lamps. The driver's side is the existing one relocated and the passenger side is a flat looking fixture (391545). The lamps' harness 6295743 plugs into where the existing courtesy lamp plugs into. Lectric Limited has one (40504 GTO courtesy lamp harness) if you need it.
Name:	drv. side from below.jpg
ID:	594069   Click image for larger version
Name:	pass. side from below.jpg
ID:	594070   Click image for larger version
Name:	pass. side from the front.jpg
ID:	594071   Click image for larger version
Name:	40504 6295743 GTO courtesy lamp harness.jpg
ID:	594072   Click image for larger version
Name:	from 67 GTO Assy. Manual.jpg
Old 07-10-2022, 07:21 PM
Thanks for sharing. I didn't know that. Wonder what other unknowns are in the assembly manual. I'll have to make another pass through it.
