Old 11-11-2024, 04:29 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Money Pit View Post
How is it possible to get 460 out of hi-ports?
If it was easy everyone would be doing it.
Go fast, see Elvis!
Old 11-11-2024, 04:32 PM
Money Pit's Avatar
Money Pit Money Pit is offline
Originally Posted by Dragncar View Post
Marcella got 462. Some here tried to say it was not true.
If he could do it, Morris and co can do it.
This is all speculation, but maybe S. Brown and Marcella are involved ?
They don't crack or leak?
Old 11-11-2024, 04:51 PM
PAUL K's Avatar
None have yet.... But the cores need to be a virgin head or at least nothing larger than the commercially available "380 cfm" port
Go fast, see Elvis!
Old 11-11-2024, 05:21 PM
Dragncar Dragncar is offline
Still, not sure if these are Marcella's heads. But his work is done all in aluminum. Best aluminum welder on planet earth and he does not like epoxy.
Anyone know how Giro's new bullet is coming along ?
Old 11-11-2024, 06:23 PM
PAUL K's Avatar
Chris Razer might take acception to that comment.
Go fast, see Elvis!
Old 11-11-2024, 08:17 PM
R 70 Judge's Avatar
I don't think it's against any forum rules.
There are three programs available all based on the Edelbrock RPM head. One is a very efficient 330 plus cfm recommended for combinations up to 700 horsepower. A 350 plus cfm which is recommended for higher horsepower NA builds and max-effort boosted builds. A wide-port 410 plus cfm program which is recommended for 1k plus horsepower NA engines or serious effort nitrous build. Also offered is a 460 cfm program for Hi-ports.
Pretty cool! Is there a smaller highport program available or just max effort stuff? Like something that doesn't need offset lifters
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Old 11-11-2024, 08:22 PM
PAUL K's Avatar
Thanks, just the one program for Hi-ports. We can always hand grind the Hi-ports they're a pretty straightforward head.
Go fast, see Elvis!
Old 11-11-2024, 10:10 PM
slowbird's Avatar
slowbird slowbird is offline
His doesnt show its using 460cfm.
Old 11-12-2024, 12:51 AM
Just asking how his car is going.
JM had his own thread here about his High Ports.
Old 11-12-2024, 12:54 AM
What do you think a High Port can do with no offset, no epoxy and a 2.20 valve ?
Old 11-12-2024, 10:31 AM
lakefect lakefect is offline
sorry to get off subject but who would be the man to fix a set of leaky [water] hi-ports?
Old 11-12-2024, 11:15 AM
steve25 steve25 is online now
KRE can’t do it or recommend someone?
Old 11-12-2024, 11:17 AM
PAUL K's Avatar
Our welder retired recently. Chris Razer would be an excellent choice to weld the head.
Go fast, see Elvis!
Old 11-12-2024, 11:18 AM
PAUL K's Avatar
No they can't
Go fast, see Elvis!
PAUL K's Avatar
400ish
Go fast, see Elvis!
Old 11-12-2024, 12:02 PM
mysticmissle's Avatar
i had my set fixed with weld, i believe it was two of the middle intake ports, at carlquist engines in waterbury/oakdale ct. (he said it was a muther lol) not sure how far that is for you. definitely pontiac friendly and very capable shop
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-12-2024, 01:12 PM
PAUL K's Avatar
This may be a good option.
FWIW I've found dealing with a professional welder is a better choice. They will just make the repair and move on to the next job. Professional's will not complain about the difficulty of the job .... They'll just fix it.
I remember picking up a pair of RAIV heads at a very appealing price years ago. Against my my recommendation for fixing them, the guy took the heads to a very reputable head shop. He was told "if they can't fix'm no one can". Well when the heads were deemed unrepairable I purchased them for scrap. I sent them to the guy I originally suggested and $150 later they were repaired. We raced them for several years and then sold them to a nostalgic road racer.... They're still in service today.
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
  #38
Old 11-13-2024, 10:53 PM
400ish
How much work to get a Victor to keep up ?
Does it need cut in half ?
  #39
Old 11-23-2024, 02:28 AM
blueghoast's Avatar
400ish
hmmm close to my speedmasters LOL
GT
The Following User Says Thank You to blueghoast For This Useful Post:
  #40
Old 11-23-2024, 09:24 AM
PAUL K's Avatar
Full port job for sure. I've never cut a Victor in half. I save that for dual planes. The only reason to cut a manifold in half that I know of is to gain easier access to hard to reach areas or put an aftermarket manifold on an old four cylinder.
Go fast, see Elvis!
