Old 11-11-2024, 05:14 AM
64speed's Avatar
64speed 64speed is offline
Default Weird gas pedal problem
I have the factory metal core rubber coated accelerator pad. I know it’s the way my foot rests but I keep bending it. Once it’s bent it makes it hard to take off smoothly. Has anyone else had this problem? Any suggestions to stiffen the pedal?
Old 11-11-2024, 05:59 AM
steve25 steve25 is offline
The more you bend metal( or in your case something with a metal core ) and bend it back again the easier it will bend again and also that rubber outer layer is likely dry rotting and adding nothing in terms of added support.
I would say it's time for a new pedal .
Old 11-11-2024, 10:12 AM
grivera's Avatar
grivera grivera is offline
Is the throttle return spring really stiff?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'69 LeMans Vert, 350, #47 heads: work in progress
Old 11-11-2024, 11:01 AM
Singleton Singleton is offline
I put a 66 pedal assy in my 64, as I really dislike the 64-65 design
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac.
70 Formula
Old 11-11-2024, 12:58 PM
64speed's Avatar
What’s involved in this?
64speed's Avatar
No not really, no one that has driven my car has said anything.
Old 11-11-2024, 01:15 PM
As I recall, it was a pretty straightforward swap once you get a donor pedal assy
70 Formula
Old 11-12-2024, 01:23 AM
Skippy597's Avatar
Skippy597 Skippy597 is offline
If interested I think I have a spare pedal assembly from my 66 parts bin.
Edited to add that it is in rough shape but completely usable.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Thread Tools
Display Modes
