Old 11-11-2024, 10:30 AM
chrisp chrisp is offline
Default PCV valve/center carb
Opinions on ditching the F fitting vacuum source & using what i have is a non original center carb rear vacuum source for PCV valve signal.
Old 11-11-2024, 10:45 AM
Kenth's Avatar
Kenth Kenth is offline
Could work if you have a 1/4" NPS hole for a 90° 1/4" NPT fitting for a 3/8" hose.
Would look odd though.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-12-2024, 12:13 AM
Why change something that works? Plug the carb vacuum source.
Old 11-12-2024, 12:15 AM
GtoFM's Avatar
GtoFM GtoFM is offline
How I understand it is the F fitting references vacuum from each plane of the manifold to give an average. If the same result could be achieved from the carb base, why didn't Pontiac engineers do it that way? What am I missing?
Old 11-12-2024, 04:53 AM
Kenth's Avatar
Lack of space for a 1/4" 90° fitting between center and rear carb?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-12-2024, 08:23 AM
Thinking it would be better distribution of the crankcase heat & fumes rather then into the unbalanced intake runners.
Old 11-12-2024, 08:24 AM
The factory center carbs do not have the port , as stated this is a non original center carb on a 461.
Old 11-12-2024, 11:01 AM
Kenth's Avatar
Look closer to the upper and lower plenums under the carbs and youŽll notice that there are no unbalanced distribution of crankcase fumes to singel intake runners with the original setup.
And, most original center Tri-Power carbs has a 1/8" NPS threaded port back of the throttle plate for a fitting to distributor ignition vacuum advance.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-12-2024, 11:22 AM
pfilean's Avatar
pfilean pfilean is offline
Early PCV option was a plate (probably a phenolic something or other) about 5/16-3/8 thick under the center carb. Then plates (thick gaskets) under the end cards so the larger air cleaner would still fit level on the three carbs. The PCV was then a tube from the front center of the center carb plate and the plate was open to both bores. PCV was the tube curved to the passenger side then a hose back to the PCV valve in the old draft tube hole. Tube was flattened to fit into the plate and sealed to not leak. It was a kind of delicate piece and probably a service problem as mechanics tried to pull the hose off the tube. Then in 63 or 64 the design changed to the F fitting. Haven't seen one of those old things on eBay for years. Last one may have been the one I bought so I could keep an original look.
Old 11-12-2024, 03:52 PM
Kenth's Avatar
Like this:
Name:	1961 Tri-Power PCV.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-12-2024, 11:34 PM
GtoFM's Avatar
OK with all the above understood, and the front carb throttle body ftg. was used for the brake booster vacuum, then why didn't the rear carb have the same throttle body as the front carb to be used for the pcv?
Old 11-13-2024, 04:37 AM
Kenth's Avatar
Location of the ignition distributor?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-13-2024, 10:50 AM
pfilean's Avatar
That's the picture Kenth. I was on the wrong computer to find the picture.
Old 11-13-2024, 04:07 PM
Dick Boneske's Avatar
Every center carb I"ve seen has either a 1/8 or 1/4 NPT hole in the base. Simply find a hose barb fitting to match the center carb base hole and run a 3/8" ID hose to the PCV valve. There is plenty of clearance between the rear of the center carb and the rear carb.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 11-18-2024, 08:36 AM
carbking's Avatar
carbking carbking is offline
Use the rear fitting for the PCV. If you also need distributor vacuum, use a hollow stud.
Jon
Old 11-18-2024, 11:52 AM
Kenth's Avatar
Some years rear Tri-Power carb lacks hole for a fitting.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Thread Tools
Display Modes
