Old 07-04-2007, 08:24 PM
frank2w87 frank2w87 is offline
Default "72 Correct Headlights
What were the correct headlights used in 1972? Were they the T3's?
Old 07-04-2007, 08:43 PM
superdutybob's Avatar
superdutybob superdutybob is offline
The correct headlamps for 2nd gen birds are Power Beams, not T3's. Check Ebay. Occassionally you can find them on there.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 07-04-2007, 11:58 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Check you local salvage yard that has older cars. They were used on GM vehicles with 2D1 size headlights from 1970 to the late 70's. Power Beams were also sold over the counter as replacements so its not uncommon to find them in other makes.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 07-10-2007, 12:05 AM
Colin70TA Colin70TA is offline
Would these be the correct ones? Ebay item # 280132429564
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, 9.66@73.5mph 1/8 mile....Sold :-(
Old 07-10-2007, 01:46 AM
2manyT/A'S's Avatar
Power Beams had a round logo in the center of the lens that said Power Beam.
Logo was about the size of a 25 cent piece.
I don't believe the ones on that auction are the ones you want,but you will need to see the actual lens to tell.
Old 07-10-2007, 02:38 AM
Dens71TA's Avatar
Auction looks like somebody is trying to pawn off some run of the mill headlights that are put into some old AC Delco/Guide boxes. It even says right in the description that the bulbs have "Westinghouse" on them.
The original bulbs will have "Power Beam" in a circle and "Guide" on the lens. Guide is/was GM's lighting division.
Old 07-10-2007, 01:51 PM
thanks everyone for the input. there is a guy selling them for $225/pair also. Crazy stuff.
Old 07-10-2007, 02:36 PM
Dens71TA's Avatar
Power Beam in all it's glory. $225 is CRAZY! My set was $2.
Old 07-10-2007, 04:50 PM
carcollector's Avatar
carcollector carcollector is offline
I believe I have a box of these headlights. Most have that haze at the top, as most do. I'd have to check which ones still operate. Let me know if you're interested.
BTW, was it you I sent that hinge cover to? If so, did it work out OK?
Old 07-10-2007, 06:10 PM
It is I. The hinge cover was awesome-Thanks a bunch. I would like to buy those power beams if you have them.
Old 07-11-2007, 12:08 AM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
frank2,
grab these up, if not I would like to be second in line for these PB's
(buy now) I need a set as well>>>>>>>>grin>>>>>>>>>>>!!!!!
73 SD TA auto.
73 SD TA auto.
74 SD TA auto.
74 SD TA 4spd.
72 442 W-30 auto, post coupe Bamboo. 1 of 19 total.
90 300zx TT 5spd.
Old 07-11-2007, 12:30 AM
Frank, pm sent. SDD, I hear ya.
