Old 04-12-2024, 10:30 AM
pontiac_boy pontiac_boy is offline
Default Cranks for boosted applications.
Little bit of a noob here when it comes to boosted Pontiac but I wanted to get a general understanding on y’all’s experience and opinions on cranks.
I’m in the initial process of collecting parts for a Boosted drag and drive motor. A couple months ago I called Frank at All Pontiac and made a deposit on an aftermarket iron block. While talking to him, he recommended a 4.25 bore and 4.25 stroke Billet crank.
I’ve seen previous threads from a couple years back where people have stated keeping the stroke shorter would be ideal and even some have said 4.00 and under, but I’ve also seen a few guys successfully running a longer stroke successfully. What’s the current consensus in stroke?
I’m looking to build something capable of mid nines initially with room to grow as I gain more experience with the combo. So I’m figuring in a 3600lb car I probably need to be in the 1k-1200hp range?
Am I crazy?
Old 04-12-2024, 12:48 PM
performerrpm's Avatar
performerrpm performerrpm is online now
have you received your block? i put my deposit down 2 months ago as well and hoping it gets here soon.
frank rec'd me to go with a 4.35 bore with my roots blown build and at the time i was gonna use my 4.0 crank . i instead used that crank in my 400 and going to run a 4.250 crank in the ia2 block with a procharger. seams like 4.0 and 4.250 is the general consensus on boosted apps even using a new block
Old 04-12-2024, 01:52 PM
charlie66's Avatar
IMO the smallest stroke is the way to go. I go mid nines with a 3.75" stroke with a 198ci motor . More stroke will just make it harder to get down the track ..
My Half AN Injun.....
The Following 2 Users Say Thank You to charlie66 For This Useful Post:
Old 04-13-2024, 09:17 AM
So I talked to him in mid February and he said I was 9 or 10 on the list. He said he wasn’t sure but he was expecting them to be done at the foundry in a couple weeks but we’d then be at the mercy of the machine shop after that. I hope to hear something this month but I’m not expecting anything as I’m not in a rush.
It seems like a decent amount of guy’s suggest the shorter stroke I’m just trying to better understand why. And those billet cranks are a big purchase.
Old 04-13-2024, 12:59 PM
charlie66's Avatar
The reason why is that with a turbo torque becomes so multiplied it becomes a problem to get traction. So a short stroke will help you in that respect.. You still will have more torque then you will need with the shorter stroke. Im building a motor now with 3.330 stroke because even with 3.750 stroke it was too much imo...
Old 04-13-2024, 04:45 PM
dang we must have ordered within days of each other lol. i ordetrd around the 16th of feb and was number 8. i hit him uo yesterday and he said its at the machine shop.. im not really in a hurry either...i think my 434 will be plenty while i piece together the new one
Old 04-16-2024, 03:18 PM
Dragncar Dragncar is offline
Lots of big power boosted Pontiacs with 4 inch strokes out there. Its what Chief ran.
Old 04-16-2024, 06:08 PM
Am I crazy?
John Meany had a 1000 hp Small Block Chevy STREET engine in a Corvette 25 years ago that he drove everywhere at low boost (less than 15 psi of boost) John Lingerfeller was involved in the project.
A YSi Vortech Supercharger would make 1200 in a street car with a basic BB Chevy engine years ago. A Procharger supercharger can easily make the same power.
A boosted Pontiac Turbo Engine (one turbo) would require a Large turbo (or 2 turbos ) and would be very soft on the bottom unless paired with a 400+ cid engine.
Old 04-16-2024, 10:04 PM
blueghoast's Avatar
Mine is a 400 ci 60-over make's a ton of power no dyno numbers.
I just bump the cam a bit to a solid roller I'm hoping for 1-1200hp
with iron heads, When I get the 77-firebird done I'm going to install
it in that might be a while unless I just have to know and put it one of
my other cars. I might dyno it this time too.
GT
