Source for 63 PS high pressure hose?
Does anyone have a source for a 1963 389 PS high pressure hose, ready to bolt on? The car is a wagon, but I don't think it matters.
I took mine to a local hydraulic shop and it came back 8" too long with 2 added connections......At least I still have both original end fittings. The new hose installs, but looks very messy. Thanks in advance, James Q |
Well, why not take it back and ask them to remake it but this time to the correct length as per your sample? That seems the logical way to go. Nothing hard about making one.
To laugh at men of sense is the privilege of fools. |
I got one for my 63 GP from I think Milton herish. He advertises in the POCI mag.
DBANDGB |
Martin Hirsch in NJ sells the hoses.
Thanks, James Q |
Thanks to Steve and Gary both for the info, I will contact Hirsch tomorrow.
James Q |
I'm assuming you paid them to do the job so in that case, why are you keen to give more money to someone else when its their error. JMHO Ian
I hadn't planned on paying them to remake it, James Q |
Hirsch,s hose does not have the crimped fitting in the middle of the hose that holds the restrictor in the hose. So if your looking for it being correct it's not
James Q |
Because he has them done at NAPA, regardless of what he says in his ad.
Pontiac engineers put the restrictor in to prevent high pressure chatter and the crimped fitting on the outside to hold the restrictor tube in place inside the hose. why would they spend the money if it was not needed.
hose
1963 power steering hose
Thanks,
I appreciate the difference in the hoses, but this will be a pleasure use only car. If I was using it for daily transportation, I would have a higher level of concern. James Q |
Thread Tools | |
Display Modes | |
