Old 12-30-2020, 07:10 PM
BOB VIDAN BOB VIDAN is offline
Default What Pulley is This One????
Can't find it in any MPCs from 1959 - 1967. It's 7 1/2" diameter, got me stumped. Yah I know, it doesn't take much.
Practicing social distancing for 65+ years
Old 12-31-2020, 06:48 PM
Gary H's Avatar
Gary H Gary H is offline
Harmonic balancer pulley, should have a part number stamped on it
Old 12-31-2020, 09:22 PM
Duh. No part number.
Old 01-01-2021, 09:29 AM
Kenth's Avatar
Kenth Kenth is offline
Only pulley i find close to 7 1/2" is 7 27/64" for 1963 421 S.D. engine.
Std 1963-67 are 7 1/4" and Air Conditioning uses 8"+ pulley´s.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-01-2021, 11:57 AM
pfilean's Avatar
pfilean pfilean is offline
61-62 P8 w/AC is 7 1/2. Non AC is only 7. Both are two groove of the same diameter. The offset is slightly different between AC and non AC. AC then takes another smaller diameter single groove pulley set into the two groove pulley before the damper is put in.
Old 01-01-2021, 12:53 PM
tom s tom s is offline
FYI,63SD balancers dont use a bolt on pulley system.They are cast with the groove and the ONLY 2 groove I have ever seen was on McKellers OHC engine.The 421 pass car engines used the bolt on pulley system.Tom
Old 01-01-2021, 01:27 PM
pfilean, my 64 MPC shows 61/2 is 7 1/2" but 3 groove.
Old 01-01-2021, 04:58 PM
My bad, haven't learned to read yet.
