Old 01-09-2021, 08:09 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 1962 GP Trunk Lid Chrome Strip Clips
Where can I get the clips to reattach this chrome piece to my deck lid? It was removed by previous owner. I found it in the trunk. See pic. Thanks
Old 01-09-2021, 08:53 PM
Those as well as the upper quarter moulding clips are like hen's teeth. Get some small butterfly clips and bolt it on. You cannot use those clips on the quarter mouldings though. The clips for the quarters must have a O-Ring seal or you will end up with a lot of water in areas you do not want water getting in.
B.T.W.: That deck lid moulding as well as the clips for it are the same on any full-size Pontiac for '62
The Following User Says Thank You to Chief of the 60's For This Useful Post:
Old 01-10-2021, 05:08 AM
alleyCat alleyCat is offline
I have used dum dum in place of the gaskets on a few original clips. Seems to work.
Old 02-01-2021, 03:44 PM
DiamondJim's Avatar
I found these on amazon, cut the spring wire off and they work perfectly
Old 02-01-2021, 04:26 PM
That spring wire keeps the clip in place while installing
Old 02-02-2021, 01:16 AM
DiamondJim's Avatar
I’m aware of the purpose of the spring. This particular clip is too large to make use of the spring but would slide in perfectly once the spring was removed.
