65 vent control cable
I replaced my vent control cables a few years ago but it didn’t work out so well. They came with a plastic clip that doesn’t prevent the outer sheath from moving when you control the cable.
I’m trying to figure out the best way to retain the cables. There are a couple of threaded holes in the sheet metal where the cable is routed, and there is also a round hole that the cable goes through right before it connects to the flap. The only product I see on Ames site is in the attached pic. I’m not sure how it works? I also thought about a cable clamp like the metal style they have on a Holley manual choke to retain the choke cable. Is there something that is supposed to go in the round hole that the cable runs through? Thanks for any help. I gotta stop cobbling stuff together and do things right the first time! |
I would assume a screw would go through the circular area and the cable would go underneath the lip on the bottom. That would be similar to how a factory cable was mounted.
Like this
ahh! thank you so much!
