Ram air exhaust manifolds / clutch return spring
My 65 has a hose clamp around the ram air exhaust manifold to anchor the
Clutch return spring. When I am enjoying my car and shifting.. Lol. Exhaust resonance (ringing) Travels up and through the clutch pedal. Any ideas on how to reduce or stop this are appreciated. Thanks in advance. |
There should be a small hole in the exhaust down pipe fitting where it bolts to the exhaust manifold.
The spring should be hooked thru that hole. I would start there and see if it helps. |
