Old 03-08-2019, 02:23 PM
sglemans sglemans is offline
Default Turn signal flasher 68 GP
Where is the turn signal flasher unit located? Pics would be appreciated if you have them. I know it seems to be under the dash somewhere, but I looked under there and couldn't find it. Also, it is the same unit as the hazard flasher, as in can they be swapped?
Old 03-08-2019, 06:59 PM
stevep's Avatar
stevep stevep is offline
They may look different but they can be swapped. Did you look in the fuse box?
Old 03-09-2019, 01:47 AM
Not sure if the TS flasher is on the fuse box but I will check. The sound seems to come from the left side dash near the drivers door somewhere, but I just can't pin it down.
Old 03-12-2019, 11:51 AM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
Many GM cars have then attached to the lower edge of the dash (on the back) and they are pushed into a clip to hold them.
Old 03-12-2019, 12:01 PM
Not a great picture, but it shows the flasher at the lower left of the steering column. It would artach to the lower edge of the dash by a clip that wrapped around the flasher.
