1955 hood
How do you remove the 2 chrome strips down the center of a 1955 Chieftain hood?
There are inserts that hold the trim on from underside the hood. They need turned 90 degrees and will come out.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
Thanks. They just crumbled when I turned them.
I doubt you can find them, I would go to how like the 56 hood trim is attatched if you can make some pieces to work . With an insert in the hood trim with studs on it than just have a nut on the bottom side. Check with a local body shop they may be able to find something that will work.
Thats about how I figured on mounting them. I was going to braze short screws to the cross pieces and drill the hood so I could use nuts.
