Old 08-17-2019, 01:15 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default '67 Original Trunk Mat
Curious if anyone else has an original trunk mat like this one? It has a cut-out for the recessed area in the trunk floor for the lug wrench to lay in. Also, my lug wrench has a short plastic sleeve that I assume was to keep it from rattling on the floor? Looks like the reproduction mats don't have this cut-out.
Thanks,
Grant
ID:	518062   Click image for larger version
ID:	518063   Click image for larger version
Old 08-17-2019, 02:30 PM
gtospieg gtospieg is offline
I have a sleeve that holds the jack and the wrench...don't remember where I got it or if it's even for an A body. It's been sitting in the barn for a looong time.
Old 08-17-2019, 06:05 PM
Jeff Hamlin's Avatar
I personally have never seen a mat cut in that manor??
The Rubber sleeve for the post started in '67.
The one shown below is OE and in my '66 (Because I liked it)
but was salvaged from a low mile '67.
Old 08-17-2019, 09:08 PM
428ho4spd's Avatar
That extra long sleeve for the jack post makes for a nice anti-rattle fix.
The shorter sleeve around your lug wrench is what I'm used to seeing.
Old 08-17-2019, 09:39 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
My '67 still had it's original mat in it when I got the car and it was not cut out like that, it did and still does have the long sleeve for the jack though.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 08-17-2019, 10:17 PM
428ho4spd's Avatar
Interesting, I don't recall ever seeing that long jack post sleeve on any of my past '67s, but I suppose they get tossed in many cases.
Old 08-17-2019, 10:18 PM
428ho4spd's Avatar
I just found this on eBay...
Mat
Old 08-17-2019, 10:27 PM
Ducks Goat's Avatar
You must have a Chevelle mat then, was the car in question made at one of the Chevy plants?
1967 Lemans convt
Old 08-17-2019, 11:06 PM
428ho4spd's Avatar
Yes, they built both in Fremont. Being a late '67 build, they probably just used what they had available.
Old 08-20-2019, 03:50 AM
lust4speed's Avatar
Both of my original 67 sleeves (Blue GTO and the Cruiser) were shorter and both the jack post and the tire iron are in the sleeve. I don't have the original mat, but believe I would remember had it been cut out that large.
Mick Batson
Old 08-22-2019, 11:05 PM
Longs's Avatar
Longs Longs is offline
I still have the original trunk mat that was in my '67 GTO, built at the Pontiac plant, it is not cut out like that.
Old 08-23-2019, 01:01 AM
428ho4spd's Avatar
I have a feeling that they simply ran out of the GTO mats and this Chevelle mat was used as an alternative when Fremont built this car in late June of '67. It would be interesting to hear from others with their original trunk mats that have a late June built '67 A-Body from the Fremont plant.
