I have had a Mcleod mini starter in my car for 15 years no issues. ( I hate to even say it watch now it will go bad) Not sure they even make them anymore.
My machinist put a Delco full-size starter on it on the engine stand and it worked fine. He told me not to change it out for the mini starter just run a Ford solenoid. Seriously the summit starter teeth had a massive failure and they wouldn’t replace it cause it was 6 months past the year warranty
I learned this back in the '70-'80s, bracket racing. My local starter guy built me several HD factory starters, with what he said was the highest power guts that would fit in the factory housing. He told me that even the best solenoids sold, would fail from heat. And, he was exactly correct. I always took a couple of spares with me, & had some on the shelf, in my shop. Also carried at least one complete starter/solenoid, ready to bolt on at the track, if needed. That worked, if the failure was during time trials. But, if it was during elims, in the staging lanes, we were just out of luck. Last hot solenoid failure was going into round 4, at a race in 2008. Bought a Summit mini for the next race. Worked perfectly, on a 455 with #215 heads. Not saying the Summit brand is best. But, for me, MUCH better than stock type starters. |
That really didn't sound like worked fine. You know what rips teeth off of starters? Kickback. |
Well, it was 6 months out of warranty. Why should they replace it when you exceeded the warranty by 50%?
Well I am not saying its an absolute but I have been doing business with them for over 20 years. Have spents tens of thousands of dollars with them and it wasnt like I had been using it for a year and a half and it failed on the side of the road. It was a non start right out of the gate.
Maybe everyone isn’t perfect like you and fall behind because life events like major dental work get in the way
Never argue with someone who's a parts pusher for a living.
i got a jegs mini starter, have had it for years no issues. sometimes you just get a bad unit., its called a monday or friday unit.... on friday the people are in a rush to get done and screw it up, on mondays there hung over from the weekend and screw things up...lol
1970 firebird, 468, e heads, |
I am in the process of putting in a summit mini. How did you guys check the gear backlash? The starter came with good instructions but I can’t physically SEE inside the bellhousing to check the lash using a paperclip like they show. The big aluminum block that the starter motor bolts to isn’t helping.
Any suggestions? |
Doesn’t have the skill to be a mechanic but likes cars. I know what I’ll do. I’ll go work for autozone LOL
Actually, it worked fine. Three times. And then *something* happened.
Starters are tough, but they simply cannot compete against an engine's output. Something had to yield. |
Well I called summit back now that I am not rushed to talk and they are sending me a new one so goes to show customer loyalty goes a long way.
If you're using Chief as your role model, it just shows how little you know about cars. Chief tried to tell me I had alignment issues on my wife's Camaro based on the "wear" pattern on the tires in this photo. The tires were brand new and had only been on the car for about an hour at the time the photo was taken... Some people post a lot. Doesn't mean they understand anything about cars. |
#38
The things Chief doesn't know could fill a library, his condition is known as verbal diarrhea.
#39
Oh, and bring your cash. LMMFAO!!!!! |
#40
My Robb Mc has been flawless for quite a few years now.I added the pinion support on the last motor refresh when the compression was upped.
