70 81 trans am firebird parts
all parts pulled off 73 to 81 trans ams or firebirds i am located in davison mi 48423 10 miles east of flint email me at thefbodygarage@aol.com
4 speed hump 40 4 speed ball stud 10 4 speed fork 20 301 turbo intake 50 301 turbo valley pan 40 301 turbo valve covers 60 301 oil dip stick 20 Air intake tube on inner fender 30 2 available Air intake tube lower duct only on 301 turbo cars 75 2 available Air intake duct bracket 10 A pillar covers black 75-81 30/PR 11 PR available A pillar covers in primer 30/PR 3 PR available A pillar covers 70-74 75/pr Arm rest 78-81 100/PR 5 PR available Arm rest 78-81 driver side 60 Arm rest bracket 73-77 10 each 4 available Air intake duct 15* a/c dash bezel vent 30 a/c wireing 30 2 available a/c brackets small block chevy 100 2 available a/c brackets 301 pontiac 80 a/c fresh air intake flapper 45 2 available accelerator cable bracket 10 5 available Accelerator cable 10* Ash tray rear arm rest 10 each 12 available Alternator bracket pre 69 20 4 available Alternator bracket 30 5 available Alternator bracket 80 amp 70 Alternator bracket 2 piece 50 Blinker greens 10/pr Brake booster, master cylinder, proportioning valve combo disc/disc brake 40 2 available Brake release 15 2 available Blower motor houing non a/c 50 2 available Blower motor housing a/c 100 4 available Bolts 12 point fender bolt 5 each 10 available Bolt harmonic balancer bolt 5 Bolt for t top handles 5 each 3 available Bolts for body interior esc 1 each Carb 75 4 speed Pontiac 200 Carb 77 4 speed chevy 200 Carpet guard 5 Center console 60 3 available Center console camel auto 100 Center console bucket 20 2 available Center console map pocket 30 4 available Cigarette lighter 5each 2 available Charcoal canister 10* Cruise control module 30 3 available Column cover 10* Cowl screen 10 5 available Core support 77-81 100 3 available Column cover 30 Crossmember th 400 or Muncie 4 speed 100 2 available Crossmember th350 or Saginaw or st10 4 speed 50 2 available Crank pulley 30 5 availble Core support bushing NOS 15/pr Coolant jug 20 Core support braces 20 8 available Dash bezel firebird 10* Dash bezel non a/c bird decal 15 5 available Dash bezel lights wiper washer decal 5 Deck lid 50 3 available Dash radio section uncut 30 Dash 100 Dash bezel rings 25/ set 8 available Dimmer switch 10 2 available Disc brake rear calipers 5 1 passenger side available 2 driver side available Disc brake parking brake brackets/hardware 60/PR Disc brake parking brake brackets/hardware passenger side 25 Disc brake backing plates 100/PR Disc brake proportioning vale 50 Distributor hold down 10 Door passenger side 75 Door panels 73-77 upper and lower 100/pr Door hinges with new pins installed 70/set 5 available Door panel arm rest pads 73-77 10 each 5 available Door driver side 75 available Door handle rods 5 each 5 available Door latch passenger side 25 2 available Defrost duct a/c 20 Defrost duct non a/c 30 2 available Exhaust bracket bolts to trans 20 4 available Exhaust bracket bolts to cat converter 40 4 available Exhaust hangers 40/pr Engine lift bracket 10 2 available Engine mounts 60/pr 4 available Engine mounts small block chevy 35 4 available Fan clutch 15 Fan with clutch 40 Fan shroud 100 4 available Fender firebird 70-73 RH 100 Fender Trans am 74-81 LH 150 Fender extensions 40/pr 7 available Fender brace 10 22 available Fender patch panel 30 each 1 driver 1 passenger Fender cut outs 100/pr Fender cut out RH 50 Flares rear 79-81 30 each 3 driver 3 passenger available Flares front 79-81 30 each 1 driver 1 passenger available Filler panel 20 3 available Fischer t top bags 60/pr 2 available Front bumper bracket 77-81 nose to frame 50/pr Front bumper bracket 79-81 middle 10 9 available Front bumper bracket 77-81 10 each 27 available Front bumper bracket 74-76 10 Front bumper bracket lower 74-76 60 Front bumper bracket 74-76 60/PR Front bumper bracets 74-76 upper brackets 20/set Front bumper bracket core support to nose 74-76 40/pr Front bumper brackets 60/pr Front bumper bracket core support to nose 70-73 40/pr Front bumper brackets 70-73 125/pr Front speaker brackets 80-81 20/PR Front speaker grills 20/PR Front speaker bracket 70-79 10 Fuel door bracket 79-81 50 6 available Fuel door bracket 79-81 15* Fuel door 70-73 45 Fuel door 74-78 10* Gauge speedometer 80mph 20 Gauge speedometer 100 mph 40 Gauge speedometer 160 mph 60 Gauge dummy lights 20 Gauge fuel level 20 2 available Gauge fuel and volts 30 Gauge plug 10 Gauge lights 1 each 10 available Gauge housing 10 Gas pedal with brackets 20 Gear box cover 20 2 available Gear box ws6 50 Grills 79-81 75/pr Grill 74 15* Grills 73 100/pr Grills 77-78 75/pr Grill brackets 73 40/pr Glove box door non a/c 30 Heater core housing 20 Headlight mounting plate 70-73 10 1 available* Headlight trim rings 74-76 10 for 5* Headlight buckets 74-76 20/pr Headlight trim rings 79-81 5* Headlight buckets 77-81 10 each 11 available Headlight bezel 79-81 10 each 14 available Headlight switch 10each 6 available Headlight mounting plate 70-73 20 1 available Headlight screws 79-81 3 each 20 available Heater controls 77 only 75 Hurst t top bad 100 Heater controls 78-79 75 2 available Hood latch 30 12 available Hood latch 74-76 with rod and bracket 60 Hood latch rod 74-76 15 Hood chrome trim 20 Hood cable bracket 79-81 25 2 available Hood cable bracket 77-78 30 Hood hinges 30/PR Hood popper 10 8 available Hood hinges 60/PR 12 driver side 11 passenger side Horn contact 25 4 available Hush panel 50 Intake aluminum small block Chevy 60 Inner fender driver side 30 5 available Inner fender passenger side 30 6 available Intermediate shaft 78-81 20* Inner fender brackets 25/pr 4 available Intermediate shaft cover 10* Intermediate shaft 70-78 60 Intermediate shaft 79-81 60 2 available Jack hook 10* Jack set up 120 2 available Jamb vents 5 each 6 available* Kick panel diaphragm a/c 25 Kick panel accuator cover 10 2 available Licensee plate bracket front 74-76 30 Leaf spring pockets 40/pr Manual window regulators 40/pr Mirror driver side 40* Mirror handle bezel driver side 10 3 available Non a/c firewall cut out 20 Nose cone 70-73 120 Oil pan Pontiac 40 Oil pan Pontiac 60 2 available Oil pan small block chevy 30 Oil filter adapter 40 3 available Power steering bracket 301 10* Pulley set small block chevy 60 Power steering bracket 50 3 available Power locks 15 13 available Power steering pulley 30 6 Power windows 30 3 available Power steering brackets 403 50 Positive battery cable protector 15 4 available Power trunk lock button 15 3 available Power window wiring 60 2 available Proportioning valve bracket 15 Parking brake 30 Radio bezel 20 2 available Radiator bumps 5 each 9 available Reverse lockout rods 30 2 available Rever lock out lower rod 10 Reverse lock out complete 50 Reverse lock out frame cups 15 each 3 available Reverse lock out swivel 4 speed 35 2 available Rear bumper brackets 74-76 60/PR Rear end mounting pads 15 each 8 available Rear end bumps 40/pr Rts emblem 10 2 available Radiator mounting tabs 5 each 10 available Rims Pontiac rally sport II 100/set Rims 7” snowflakes 200/set Rims 8” snowflakes 300/set Rims 8” snowflake single 120 2 available Rear arm rest 120/pr 3 available Rear arm rest passenger side 60 Rocker arms 5 each 14 available Seat trim lower 10* Seat backs 50 each 6 available Sail panels 100/pr 75-81 4 available Sail panels 74 only 100/pr Sail panels 70-73 100/pr Seat belt cover 20/pr 2 available Space saving spare 20 2 available Space saving spare 150 Seat belts 125 a set 4 available Seat belt holders 70-73 75/pr Seat track feet covers 5 each 13 available Seat tracks 75-81 200/set 8 available seat track driver side inner track 25 9 available seat black vinyl driver side firebird 60 subframe reinforments on ws6 cars only 30 each 11 available super t 10 4 speed with shifter and bellhousing 700 seat track Passenger side 75/set 18 sets available seat track Passenger side out side track 50 3 available Side markers front 10* Shifter auto bump style 100 3 available Shifter auto 60 Shifter knob w/ red bird button 20 5 available Shifter knob w/ gold bird button 40 Shifter knob w/ arrow head 20 Shifter knob red bird button 15 2 available Shaker Pontiac 400 100 Shaker no base uncut 60 Shaker no base cut 40* Shaker base 403 60 Shaker base 400 60 3 available Shaker ring 40 Side marker bezels 30/set Side mirror gasket 5 10 available Steering wheel hub 25 5 available Steering column tilt w/ key 79-81 100 3 available Steering column tilt with key 70-78 125 Steering column tilt with key 4 speed 70-78 150 Steering column non tilt 70-78 with key 75 Seat rear 50 2 available Seat backs 73-77 50 each 3 available Spoiler middle 30 3 available Spoiler ends 79-81 30/pr 3 pair available Spoiler ends 74-78 75/pr 1 pair available Spoiler end 74-78 LH 40 Spoiler ends 70-73 75/pr Steering wheel horn button bird decal 15 2 available Steering wheel center cap black w/ red bird 30 Steering wheel center cap camel w/ gold bird 50 Steering column bracket 10 Sway bar front 1 ¼” 40 Sway bar rear 20 5 available Sway bar bracket rear 10 11 available Sway bar bracket drop link to frame 10 16 available Subframe bare good mounting points 100 Subframe complete 100 2 available T top roof cut Hurst t tops 200 T tops Hurst 300/PR T tops Hurst single 150 T top handles fischer 40/pr 2 available T tops fisher black tinted 50 each 8 available T tops fisher gold tinted for y88 300/PR T top fisher gold tinted for y88 RH 150 T top fisher mirrored for 10th anniversary LH 150 T top latches 60 set of 4 Trunk latch 10 3 available Torsion rods for decklid 40/pr 5 available* Transmission Th 350 core 60 Transmission shifter cable 10 2 available* Trans cable bracket 15 Tail light wiring to fuse box 20 Timing chain cover 60 3 available Trunk courtesy light wiring 25 Turbo wiring 75 Transmission kick down cable 15* Taillight lenses 79-81 20* Tail light passenger side 79-81 20* Taillights 74-78 with grill 50/PR Taillight wireing 79-81 25 5 available Taillight wiring 74-78 30 Taillights 74-78 with grill 100/pr 2 available Taillights 79-81 complete set 250 3 available Taillights 79-81 no fuel door 200 Taillights 79-81 passenger side 100each 2 available Taillight nuts 79-81 1each 50 available Taillight wire retainer 74-78 3 each 8 available Turn signals 79-81 pair 15 2 available* T top headliner clips 3 each 10 available Turn signal LH 79-81 5 * Turn signal RH 77-78 10* Transmission cooler 20 2 available Trim drip rail 50/PR 4 pair available Trim for rocker 20/PR 2 available Trim windshield black 50 6 available Trim rear window black 50 3 available Trim rear 70-74 150 Trim fender 10 each 4 available Trim chrome rear 75-81 50/set 2 available Trim chrome front 50/set 5 available Trim drip rail 70-74 250 Trim front chrome windshield NOS 150 Turbo hood scoop 40 Thermostat housing 10 11 available Rear arm rest 40/PR Rear bumper 74-76 80 Rear differential cover 10 Rear end 308 drum brake posi 250 2 available Rear end 373 drum brake posi 400 2 available Rear glass non defrost 75-81 60 4 available Rear glass with defrost 75-81 60 2 available Rear defrost switch with bezel new decal 40 Rear glass 70-74 80 Rear speaker grills 60/PR 2 available Roof cut 70-74 150 Visor mount 10 3 available Visors 50/pr 12 available Washer jug 20 2 available Water pump pulley 30 5 available Windshield 50 Windshield wiper switch non delay 10each 3 available Windshield wiper switch delay 20 Windshield wiper switch delay very nice 40 2 available Windshield washer jug 5* Wiper arms 30/PR 8 available Wiper motor mounting bracket 20 2 available Windshield trim eye brows 35/pr Windshield trim eyebrow LH 20 Windshield wiper trans 20 5 available Wire cover under sill plate 80/pr Wire cover under sill plate passenger side 25 2 available |
Hey Woogie...
I'm interested in the fan shrouds. Could you email me pictures and a phone number so I can give you a call. Thanks, Tim tim@stagecompany.com
69 GTO 400, 4-Speed, Matador Red 69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack 72 Trans Am, 455HO, 4-Speed, Lucerne Blue 73 Trans Am, SD-455, 4-Speed, Brewster Green 73 Formula, 455, 4-Speed, Ascot Silver 73 Formula, 455, Navaho Orange Survivor |
i forgot to mention most of these parts have been media blasted and painted polished or just in very good condition
Interested in T 10 4 speed set up. Also need reverse rod s to column. What year is the trans?
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
Interested in very good driver quality black 4spd console? And I think I asked you this before but I'm looking for a dash mounted elec. door lock switch.
Frank
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Looking for a 4bbl Accelerator Cable (72/73 interchange - I have some measurements)
Fan Shroud 927 Alternator |
Woog,
Do you still have: "Steering column tilt w/ key 79-81 100 3 available" ? Is that all I would require to convert from fix steering column to tilt column or is there additional hardware needed? Will you ship to the great white north? thx. |
yes this is everything you will need i can ship please email me direct at woogie0004@aol.com as i do not get on here to often |
sorry none of those parts
I'm looking for a buckle for a deluxe door pull- I'll buy (2) if you have them.
dash parts
Do you have non-ac ducts for the upper vents 70-81 firebird?
INTERESTED IN
Drivers side a pillar cover fro 78TA Shipped 19508 pa
Do you still have the 160 speedo for $60? If so condition of it and picture. Drivers side visor mount? I need one that is in good shape and does not sag.
1972 GTO, Lucerne Blue, M22 Rockcrusher. 1974 Ram Air Formula 400,4spd,3.42 posi,honeycombs,much more.Rare Bird(sold). 2005 GTO Midnight Blue 6spd( sold). |
Email sent.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
PM sent.
Fender
76 trans am fender available?
Spoiler ends for 79 still available?
