Old 12-14-2019, 10:32 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Default WTB: Unobtainium battery cable clips 70-71 bird
Looking for a set of battery cable are harness routing clips that mount on the engine mount to block bolts and hold the battery positive cable as it routes up to the starter.
Hard to find bits indeed.
Part numbers are 481216 for the front and 478655 for the rear of the mount.
Please PM me if you have any that you are willing to sell.
Rob
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 12-15-2019, 08:05 AM
chuckies76ta's Avatar
Checkout Inline Tube. They have alot of small restoration parts.
https://www.inlinetube.com/
Old 12-15-2019, 11:49 AM
694.1 694.1 is offline
Got a photo? Inquiring minds want to know...
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 12-15-2019, 12:19 PM
This is a picture of the driver side front clip on a 1970 Trans Am. I do not have a picture of the rear one.
Old 12-15-2019, 01:20 PM
Held for Ransom's Avatar
So long, farewell.
Old 12-15-2019, 02:46 PM
RAJ7395's Avatar
Thanks for the pic HFR!
Yep - Those are the little rascals that I'm trying to find. I need two sets for my birds.
Old 12-16-2019, 06:38 PM
http://www.forums.maxperformanceinc....d.php?t=414940
Here is the thread where I posted the picture.
So long, farewell.
Old 12-16-2019, 07:08 PM
mgoblue mgoblue is offline
Might be able to bend these to work.
https://www.heartbeatcitycamaro.com/...-Sold-As-Each/
You got the teeth of the hydra upon you.
Bang A Gong, T-Rex
Old 12-16-2019, 08:26 PM
steve v's Avatar
steve v steve v is online now
Here's Inline Tube's clip, I've used them before w/good results.
https://www.inlinetube.com/pages/pro...umber=inl11075
Old 12-16-2019, 09:16 PM
http://www.forums.maxperformanceinc....d.php?t=804715
Found the pictures of the clips alone.
I wish there was an easier way to search one's attachments (mine is over 2300).
So long, farewell.
Old 12-18-2019, 11:41 PM
henley henley is offline
Default rear clip
I have a used one and a nos one bought from a member here, let me know if you are interested in either. chuck
63 Z-11 JACKSHAW CHEVROLET CAR
67 PLUM SAFARI WAGON
68 ROAD RUNNER HEMI 4- SPEED
69 RA V JUDGE
70 RA III 4- SPEED CONV. GTO
73 FIREBIRD
98 MUSTANG CONV
05 LEXUS SC430 CONV
08 LEXUS ES350
15 SILVERADO
Old 12-19-2019, 08:59 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Are you sure these are '70-71 only? My '74 looks to have the same clip that holds the positive battery cable on the drivers side engine mount. I also have a 1976 400 that I pulled from a Formula that has two of these on the drivers side. Seems likely any Pontiac engine bird would have them.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 12-19-2019, 10:14 PM
RAJ7395's Avatar
No- I'm not sure of the date range when these cable clips were used. I just know that they were on the 70 RAIII and 71 455HO engines and that mine are missing.
3tas4me - So do you have a set for sale??
I'm converting my 70 formula to the RAIII exhaust system and will need a third set for that car as well.
Rob
Old 12-29-2019, 10:18 PM
3tas4me's Avatar
Rob
I don't have any for sale, but I think you could find them on almost any Pontiac V8
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 12-30-2019, 01:11 PM
tigertone tigertone is offline
Default Clips
I have found the foward clip used on the 71 and 72 Lemans two barrel cars. But It is not mounted to the block under the first motor mount bolt hole. It is bolted to the block in the bolt hole in front of it closer to the fuel pump. It is usually hard to see covered with grease and road grime. On these years they routed the cable down the front of the motor,not like the 70 Abody V8 non ram air car that went through the tube between the exhaust manifold. If you look at the clip it has two tabs in the top at either side. These lock it in place against the raised casting of the block where it mounts. Keeps it from turning I guess. The other longer clip used on the rear motor mount bolt hole is like the one they repro at Inline Tube. In the pics attached, one clip has the rubber coating removed.
ID:	527782   Click image for larger version
ID:	527783   Click image for larger version
Old 12-30-2019, 05:31 PM
RAJ7395's Avatar
Yep those are the little rascals I'm trying to find!!
Old 12-30-2019, 11:59 PM
So, from what I can see...
The front clip, Group 2.343, PN 481216 (or 1484897), was used on F-body '70 RAIII/IV; A- and F-body, '71 455HO and all '72s.
Rear clip, Group 2.343, PN 478655 was used on A- and F-body '70 RAIII/IV and '71 455HO.
So long, farewell.
