Old 07-05-2023, 01:30 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
Default Replace Drivers Kick Panel
Non AC car - need to remove and replace the drivers kick panel. I searched and found a couple of posts, but not a lot of info.
Sounds like the e-brake needs to come out? Along with a handful of screws and the cable connection to the vent door. The posts I did find indicated that the bolts for the e-brake are difficult to get to.
My car is currently at the bodyshop - is this something I should be doing now before the fenders go back on or does it not make any difference?
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
Old 07-05-2023, 01:43 PM
nas t eh nas t eh is offline
While it would be easier with the fender off. There is enough room between the brake vacuum booster and the fender to put the nuts on the E brake bracket on the engine compartment side.
73 T/A 455, 4speed
The Following User Says Thank You to nas t eh For This Useful Post:
Old 07-09-2023, 05:10 AM
Trevor78 Trevor78 is offline
Magnetic tools can help when access is limited. The kick panels wrap around the body opening, can't be installed until after that area is painted, if that matters.
Thread Tools
Display Modes
