Anti Pump Up Lash Adjusters
Hello All
Been going through my OHC 6 stash of 25-30 years, wanting to build me a screamer. Found a Set of Johnson VL-60 Anti Pump-Up Lash Adjusters for the Ol'e Cammer. Anyone ever used Johnson Anti Pump Up Lifters or Lash adjusters in the days of 25-30 years ago?? I also have a Sig Erson 290 Deg. Cam still new on the shelf, a set of 12.5 CR pistons, 6 Inch Rods and Total Seal Rings. Smokey Unick used to say, "Put the LONGEST RODS you can in the engine", 6 inch is about as long as you can go without going Crazy with the Pistons or Crank I guess. My finances are pretty tight these days due to Family Obligations, but I do have allot of things in storage that won't cost me anything now, so why not right. I am Officially Retired these days, so guess I will have some fun. So what'ya think? Take Care, Dusty |
I dont see how youre going to use a 12.5 CR piston and a 6 inch rod.
what is CH of the rod? Ive used alot of the Johnsons,Melling was the major supplier of them. I think you need more cowbell(cam) if you re running 6 inch rods and a 12.5 CR. off course youll need ignition,exhaust and intake mods to match.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Hello
The Pistons are Shorties, the wrist pin bore just clears the oil ring grove by about .090 in. The Rods are 6.0 in. C/C The ol'e Sig Erson 290 Cam should work pretty well I think. If not I can have my BILLET BLANKS ground that I have in my link, then I can really go CRAZY with the Cam. The distance from the top of the wrist pin bore to the flat top of the piston is .910 in. It has 1/16" rings and 3/16" Oil Ring, pretty tight grouping. Piston OAL is Approx. 2.300", plus the 12.5 CR Kickers on the top. I also have a Professionally ported and prepped head and valves. I am also running an HEI Short Cap and an MSD 6AL, Want to get a set of Primatech Headers, Maybe, Someday????? All the Parts are ON Hand now, with the exception of the Primatech Headers. Should run pretty strong I think. Take Care, Dusty P.S. How did you like the Johnson Lifters/Lash Adjusters in your engines? Last edited by BMFH; 07-02-2012 at 12:28 PM. |
I use nothing else unless the OEMs are new. I did have one set that had a tick. warehouse said bring back the bad one and they will replace. I asked how to access and test to isolate and they agreed,gave me a new full set, problem cured. I should have investigated but at time had alot of other things on my plate.
